Bike problems
Old Jul 5, 2008 | 08:31 AM
miacycles's Avatar
miacycles
Default RE: Bike problems
On and off with an occaisional pop sounds electrical. Chek all battery connections first, then check the other end of the cables and make sure they are tight also. Then take all the electrical connections apart and look for corrosion, clean them and put some di-electric grease on them. This doesn't take too long to do and you can do it yourself. If the problem still exists then it is fuel. When you are checking the battery connections it would be a good time to put some star washers on them. Hope this helps.
Old Jul 5, 2008 | 08:48 AM
OhioSkully's Avatar
OhioSkully
Only thing that was done to the bike was when he bought it in 2003 new he had SE slip ons put on and a stage I kit and they remapped the ECM bike ran fine for last several years until now.
&nbsp\\;
It happens at cold, hot and any speed
Old Jul 5, 2008 | 08:56 AM
crash1292's Avatar
crash1292
didn't 03,s have a bad main circuit breaker?
you didn't say if everything goes dead or not
Old Jul 5, 2008 | 09:18 AM
SubZer0's Avatar
SubZer0
Check the wiring to the fuel injectors\\; they have been known to brake under the insulation from the engine moving around causing an intermittent problem.
Old Jul 5, 2008 | 09:32 AM
dougbk's Avatar
dougbk
If he loses all power when it happens it is a short causing the circuit breaker to pop.&nbsp\\; If it is like he is running out of gas, I would suspect the fuel line in the tank.
Old Jul 5, 2008 | 09:55 AM
Taterdog's Avatar
Taterdog
Like has been said, check all the connections, especially anything in the ECM/spark plug/fuel injector connectors.&nbsp\\; Clean with contact cleaner and add dielectric grease.
Old Jul 5, 2008 | 10:09 AM
OhioSkully's Avatar
OhioSkully
Does not loose all power just cuts out like a loss of fuel
Old Jul 5, 2008 | 11:12 AM
SubZer0's Avatar
SubZer0
Here is a link to what I was talking about with the injector wiring. https://www.hdforums.com/m_216195/tm.htm
&nbsp\\;
Old Jul 5, 2008 | 11:33 AM
Tinkermc's Avatar
Tinkermc
the tube you are talking about is $40.00 and the install was easy, now mine runs all the time no cutting out anymore.
Old Jul 6, 2008 | 09:45 PM
2deuce's Avatar
2deuce
pin holes in the fuel line is an emission warranty which is 18 K and change if that's what it is, it's covered!&nbsp\\; Been there-twice!!!!!!
