I'm riding an 05 Electra Glide Classic and recently changed my oil. I followed the manual and after letting it drain until empty I replaced the filter and added 4 quarts. I thought it would be a great idea to purchase a digital oil gauge to check the oil without having to remove the dipstick all the time. After taking a trip over the weekend when I got home I thought I would check the oil and the gauge indicated Hi oil? The bike was on the the kick stand and the oil temp was at 227 degrees. I don't know if I should drain some oil out or just trust the manual with the 4 quart refill? Can anyone help me out? Appreciate it.
The digital dip stick tends to do that, particularly if you check too soon after sutting down the motor. \\; Ignore it unless you're blowin' oil out the air cleaner, but if you get much oil from the air cleaner lower the oil by "about" a half quart.
I'm riding an 05 Electra Glide Classic and recently changed my oil. I followed the manual and after letting it drain until empty I replaced the filter and added 4 quarts. ...when I got home I thought I would check the oil and the gauge indicated Hi oil?
My manual for 07 says in that situation to add 3.5 quarts, which puts it right at full on the dipstick after warmup.
[align=left]Jinks and Glen are both right. The digital guage will almost always say Hi-Oil if you read it right away. If the bike is cold it may say low oil or cold oil.
The 07 (96") take 3.5 quarts with a oil and filter change.
[/align]
