lowering blocks
Old Jul 7, 2008 | 10:14 PM
bryantcm's Avatar
bryantcm
Default RE: lowering blocks
I bought a set avaiable from J &amp\\; P made by LA Choppers.&nbsp\\; They are solid billet aluminum and do not change the stock angle of the shocks.&nbsp\\; I rode with 10lbs of air in the shocks 2 up (210-me, 145-her) with no rubbing and the stock ride quality.
Old Sep 2, 2008 | 11:45 AM
kupitz's Avatar
kupitz
Default Lowering Blocks
I just bought a set of blocks from Road6 Customs on ebay and they're coming off after one ride! With two up in the 2" lowering position (they have 3positions 1", 2", and 3") the tire scraped constantly!
Old Sep 2, 2008 | 01:41 PM
spence222's Avatar
spence222
I've got 6000 miles on the Road6 Customs.......the only problem I found was the tail light assembly bolt protrudes too close to the tire...I just cut off about 3/8"...other than that you just need to keep air in your shocks.
Old Sep 2, 2008 | 01:50 PM
jimmything's Avatar
jimmything
Originally Posted by uweldit
I have a 08 RG and the ones on ebay from Road6 Customs do not fit.&nbsp\\; I ended up getting Street Glide air shocks, very happy.
Where did you pick those up at?
Old Sep 2, 2008 | 01:55 PM
kupitz's Avatar
kupitz
The first thing I checked when I got home, had 19psi in the shocks. I weigh 240 and the wife is about 135 and we bottomed ALOT!
Old Sep 2, 2008 | 06:04 PM
blueflht's Avatar
blueflht
i would suggest a set of 12" shocks from a s/g then check the posts here for an oil change. i went from 5 wt oil to 10 wt pure synthetic and the difference was amazing. no bottoming and a firmer but plush ride
Old Sep 2, 2008 | 09:53 PM
jag1886's Avatar
jag1886
Blocks are crap they bottom out all the time, if you can afford diamond cut cylinders then you should be able to afford as proper set of short shocks.
Old Sep 2, 2008 | 10:22 PM
Medicfrost's Avatar
Medicfrost
I've used White Bros for the past 2 years, and have no complaint.
Old Sep 2, 2008 | 11:45 PM
Emporers New Clothes's Avatar
I ran the ones for the road King on e-bay I believe they were white bros they did lower me almost two inches bu they do lower you by moving you back and when you ride 2 up you will bottom out. I ended up going with Arnotts ardel air adjustable shocks.
jc15025
2014-2024 Touring Models
Oct 13, 2015 03:43 PM
rich1374670x
Jul 8, 2013 01:57 PM
Hibrion
Jul 21, 2011 01:47 PM
RonRock
Mar 28, 2010 11:03 AM
TBone
Dec 18, 2005 07:37 PM
