Street Glide rear facia on an Ultra questions
I'm going to order the kit but I'm confused as to how many holes will show when I pull off the lower bumper and running light.
Pics would be great!
I'm sure there is many people with the same question.
FYI, do not buy the kits off ebay for $250. \\; You can get a new set up for $160ish from Harley
You will also have a wiring issue for the LED in the facia since it uses the TP's wiring harness for power on a stock SG. \\; Just a heads up that this won't be a plug and play installation electrically if you plan to retain the TP lighting.
And you are aware that the saddlebag \\;guard rails won't work with the facia unless the facia is modified. \\;
Good luck with your project.
The way it looks to me is.........
The streetglide has the dragger light. The plate is below the rear tail light (using the \\;tip light hole). and there are the tight bullet turn signals.
The Electraglides have tip lights. The plate is above the rear brake light.
The road glide \\;also has the plate above the rear brake light. But it has a "V" plaque \\;bolted in the lower hole where the tip light or plate would mount.
I am thinking if you take off the tip light \\;and add the road glide plaque the hole problem is solved. add the dragger/filler and your done.
Or add the whole back end of the glide (Tail light, plate mount, signals, ect).
I do not have my Ultra yet to experiment yet so I am not sure what will work.
Keep us posted.
I have taken a long hard look at all the touring models and they all seem to have the exact same rear fender. Please correct me if I am wrong.
The streetglide has the dragger light. The plate is below the rear tail light (using the \\;\\\\\\;tip light hole) \\; Wrong\\; there is no fender tip light hole in the SG rear fender or the Road Glide Fender or a Road King Custom fender. and there are the tight bullet turn signals.
The road glide \\;\\\\\\;also has the plate above the rear brake light. But it has a "V" plaque \\;\\\\\\;bolted in the lower hole where the tip light or plate would mount. \\; \\;Wrong on two counts. \\; The V plaque is a stick on emblem covering a bolt head used to secure a bracket inside the fender that ties into the saddlebag suport rails on each side. \\; And the stick on emblem \\;doesn't cover a fender tip light hole.
I am thinking if you take off the tip light \\;\\\\\\;and add the road glide plaque the hole problem is solved. add the dragger/filler and your done.
Keep us posted.
The street glide facia can be installed. You need to get a kit breakdown for P/N 91067-07 and have the dealer order the chrome plated ABS housing from it. It can be used as is (chrome) or be painted. I have installed 3 of these on bikes and did not have an issue with the S/B rails. Using another FLHX as a sample, I made 2 cardboard templates (one fer each side) of the 6 holes that must be drilled into the fender to mount the facia. The wiring is not a plug and play, but is pretty simple. Only 2 wires go to the facia's LED (power and ground).
Sounds like you are installing the tri-bar LED fender extension (that doesn't have the saddlebag filler strips of an SG facia) and the SG facia on top of the fender extension. \\; Don't see how this will work so \\;post pics of one of these installations, please.
