Help with brass inserts in inner fairing.
Old Jul 10, 2008 | 09:53 AM
Wally's Avatar
Wally
Default Help with brass inserts in inner fairing.
I'm sure I read a while back that there is a new style brass insert to replace the ones in the inner fairing that you screw into to hold the two pieces of the fairing and the windshield together.
I've had one that works it's way out regularly, but I just tap it in with a plastic hammer and I'm good until the next time&nbsp\\;I remove the batwing.
The new style I've heard about somehow screws in and has barbs (I think) so it can't pull out.
I'm 2 1/2 hours from the nearest Harley store and yesterday I was by there so I thought I get a couple.
The parts guy and I were unable to find anything on a new part for this application.
From 1996 to 2008 parts manuals, they all show the same number for the part, which ends in 96 and has no b or c on the end.
Am I loosing my mind on this?
If anyone can help I'd really appreciate it.
&nbsp\\;
Old Jul 10, 2008 | 10:02 AM
IBHarley's Avatar
IBHarley
Default RE: Help with brass inserts in inner fairing.
they havent changed them the new ones screw in and if you dont want to go 2&nbsp\\; 1/2 hr ride then order them from Zanottis or another dealer on line but order some filters or something to ease the shipping cost
Old Jul 10, 2008 | 10:24 AM
NICK56's Avatar
NICK56
GO TO&nbsp\\; ANY&nbsp\\; AUTO STORE&nbsp\\; GET&nbsp\\; 2&nbsp\\; PART EPOXY
ITLL NEVER COME LOOSE&nbsp\\; AGAIN..&nbsp\\;&nbsp\\;
IVE DONE&nbsp\\; THIS&nbsp\\; FIX&nbsp\\; MANY&nbsp\\; TIMES.. MANY&nbsp\\; HOGS.. MANY&nbsp\\;
YEARS ..
SAME JUNK&nbsp\\; HD&nbsp\\; PART... DONT THEY GET IT ???
Old Jul 10, 2008 | 10:38 AM
realbiker's Avatar
realbiker
Wally, here you go: the part # is 16585-96 ( threaded insert ) 1 per package....I have several....the cost was minor.....good luck
Old Jul 10, 2008 | 01:37 PM
Wally's Avatar
Wally
Thanks everyone.
It looks like the same part 3 that we found at the dealership.
If it's the same as what's on the bike, it probably won't help to instal new ones.
Sounds like the only way to go is with the two part epoxy.
Old Jul 10, 2008 | 02:52 PM
Mathews2's Avatar
Mathews2
If you have the stock inserts, the 16585-96 is different. the stock insert is a press fit. and the replacement is a threaded screw in type and works much better.&nbsp\\; I have already changed mine on my 07. just put the fairing screw in the insert and start it with the slotted end of the replacement insert going in first. and it will fix you right up. &nbsp\\; the epoxy will eventually break loose(ask me how I know)
Old Jul 10, 2008 | 03:21 PM
johntheone's Avatar
johntheone
I agree with NICK56, two part epoxy and a little time..
Old Jul 10, 2008 | 03:37 PM
rocknrod's Avatar
rocknrod
Yep the 08 Parts manual shows 16585-96 as well, page 93, item #4.
Old Jul 10, 2008 | 04:16 PM
stro1965's Avatar
stro1965
FWIW- Any decent hardware store sells the exact same thing.
&nbsp\\;
Old Jul 10, 2008 | 05:01 PM
CGLTD's Avatar
CGLTD
ORIGINAL: NICK56
GO TO \\\\\\\\\\\\\\; ANY \\\\\\\\\\\\\\; AUTO STORE \\\\\\\\\\\\\\; GET \\\\\\\\\\\\\\; 2 \\\\\\\\\\\\\\; PART EPOXY
ITLL NEVER COME LOOSE \\\\\\\\\\\\\\; AGAIN.. \\\\\\\\\\\\\\; \\\\\\\\\\\\\\;
IVE DONE \\\\\\\\\\\\\\; THIS \\\\\\\\\\\\\\; FIX \\\\\\\\\\\\\\; MANY \\\\\\\\\\\\\\; TIMES.. MANY \\\\\\\\\\\\\\; HOGS.. MANY \\\\\\\\\\\\\\;
YEARS ..
SAME JUNK \\\\\\\\\\\\\\; HD \\\\\\\\\\\\\\; PART... DONT THEY GET IT ???
I did the same thing except I dripped some epoxy on my fender[:@] I would recommend being careful!
