shaft extension
Old Jul 11, 2008 | 05:30 PM
choptop's Avatar
choptop
Default shaft extension
it's in their pretty tight, need to shim it out&nbsp\\; to get sprokets to line, what is the best/ safest way to get it loose, heat, slapping w/mallet ?&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;& nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nb sp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp \\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\ ; Thanks
Old Jul 11, 2008 | 07:35 PM
choptop's Avatar
choptop
Default RE: shaft extension
Having a hell of a time taking it off, any tricks ?
Old Jul 11, 2008 | 07:49 PM
Tinkermc's Avatar
Tinkermc
man I,ve been getting the shaft from my stealer for a long time and now you tell me they have an extension, thanks pal
Old Jul 11, 2008 | 07:59 PM
choptop's Avatar
choptop
Does the shaft extension include the circular part just inside of the three holes for putting the puller on or&nbsp\\;does it just&nbsp\\;have a short circumfirance around the main shaft. Trying to figure out what comes out.
Old Jul 12, 2008 | 08:04 AM
choptop's Avatar
choptop
&nbsp\\;I bought a Dial Caliper and took a measurement at the front sprocket and the clutch sprocket, their is 1/16th difference or .0625, the book says the difference between the 2 sprockets should be .030 . I realize that the space that I have is 1/32 or.030 wider but doe I really need to shim the extension, it is being a be'itch to get off, for that difference ?&nbsp\\;&nbsp\\; Thanks
Old Jul 12, 2008 | 06:33 PM
choptop's Avatar
choptop
The book and some articles I have read would have you believe the damn extension is their to grab and pull off, not this sumbitch, I can wiggle it a little as I have for hours but it wont come off, it is separarted from the rotor by a 32 nd", if they had used locktite I would think that the wiggleing would mean it is ready to come off, anyone had this problem before?
Ben221
May 22, 2017 05:58 AM
TeeStu
Jun 23, 2015 07:45 PM
cjshovel
Shovelhead
May 4, 2012 07:43 PM
Wally
Dec 4, 2009 07:44 PM
Benj
Oct 29, 2007 08:45 AM
