Accessory switch on 08 Road King
Old Jul 15, 2008 | 05:28 AM
FLHRSD's Avatar
FLHRSD
Default Accessory switch on 08 Road King
How do you wire something to the accessory switch on an 08 Road King?&nbsp\\; I have a GPS and J&amp\\;M CB I want to wire to the accessory switch.
Old Jul 15, 2008 | 09:56 PM
ddwyer's Avatar
ddwyer
Default RE: Accessory switch on 08 Road King
The accessory switch connection should be under your seat. In order to make a connector, you will need the following to make the delphi connector:
P/N 70264-94A - Two into One Harness Adapter - this will allow you to plug both accessories into the accessory switch.
Do two sets of the following - making the accessory connector for each device
P/N QTY DESC
72191-94 2 Socket Terminal
72114-94BK 1 Socket Housing
72154-94 1 Socket lock, secondary
Steps to make connector (you'll have to double check your wiring diagram to confirm I have the write lead pin numbers correct)
- Crimp 1 Socket Terminal (72191-94) on the positive lead wire.
- Crimp 1 Socket Terminal (72191-94) on the negative lead wire.
- Insert positive lead wire into pin 3 of Socket Housing (72114-94BK).
- Insert negative lead wire into pin 4 of Socket Housing (72114-94BK).
- Insert Socket lock, secondary (72154-94) into Socket Housing (72114-94BK).
- Plug completed connector into accessory switch connection under seat.
I hope this helps.
Old Jul 17, 2008 | 06:20 AM
FLHRSD's Avatar
FLHRSD
I thought that there was a connection in the headlight nacelle on the 08's
Old Jul 17, 2008 | 10:32 AM
rde's Avatar
rde
There is a connector inside the nacelle.I had a Powerlet wired from inside the nacelle and can be turned on and off by the accessory switch.I am not electrically savvy so had the dealership do it for me.It must be easy cause the labor charge was minimal.I'm sure somebody on here can walk you through the installation.There is no need to come off from the electrical box under the seat.
Old Jul 17, 2008 | 12:09 PM
iclick's Avatar
iclick
ORIGINAL: FLHRSD
How do you wire something to the accessory switch on an 08 Road King? I have a GPS and J-M CB I want to wire to the accessory switch.
If you want to just tap into 12V (toggled by ignition switch) at the ACC switch, here is a diagram of how I wired my GPS. If you want to toggle power using the ACC switch, tap into the orange (O) wire instead, but everything downstream of the switch will be toggled too.
[IMG]local://upfiles/4327/08B7B7D148FC41149441FA3E817EF058.jpg[/IMG]
Old Jul 17, 2008 | 12:13 PM
RoadKing_Al's Avatar
RoadKing_Al
When I did mine I thought it was in headlight nacelle&nbsp\\;but couldn't find it. It was located in front of the battery. A female plug. You can buy the male plug with all the parts in a package around 5 bucks at HD.
WorldPat
Apr 20, 2017 09:15 AM
Pyrotag
Apr 17, 2014 12:56 AM
07FLHRCMarinePatriot
Mar 24, 2012 03:32 AM
Flintshooter54
Apr 2, 2011 08:25 PM
Bradley Jones
Apr 17, 2010 07:00 PM
