Brass Faring inserts question
Old Jul 18, 2008 | 02:59 PM
Edgeflhtci's Avatar
Edgeflhtci
6th Gear
Default Brass Faring inserts question
Hello all...
&nbsp\\;
I have a 05 FLHTCI that is in need of replacing the&nbsp\\;factory brass inserts holding the windshield in place.&nbsp\\;I picked up three of the thread in type the other day and was told that I need to be careful installing them so as not to break off the plastic tabs they&nbsp\\;thread into. Well enough I thought.
&nbsp\\;
My question is, would it be better to pull the batwing off to insert them or not.
&nbsp\\;
An advice here would be greatly appreciated.
&nbsp\\;
Thanks
&nbsp\\;
Edge
&nbsp\\;
&nbsp\\;
Old Jul 18, 2008 | 03:52 PM
stro1965's Avatar
stro1965
Default RE: Brass Faring inserts question
You'll need to pull the outer off, I would think, in order to have room to work.&nbsp\\;
&nbsp\\;
Go slow, the tabs will break off if you're not careful.&nbsp\\; I used a tap/die set to give mine a good start and then I screwed them in very slowly by inserting the screw into them and using a drill to drive them.
&nbsp\\;
Old Jul 18, 2008 | 04:45 PM
Tinkermc's Avatar
Tinkermc
I also put some epoxy in the holes first
Old Jul 18, 2008 | 05:21 PM
Reef Rider's Avatar
Reef Rider
I just replaced mine about three weeks ago. The factory screws stripped out the holes and my windshield was beginning to rattle.
&nbsp\\;\\\\\\;
The first brass insert was my learning lesson...&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; Be very careful and take your time.&nbsp\\;\\\\\\; They actually cut new threads into the plastic as you turn them in.&nbsp\\;\\\\\\; Once they are in about half way they get very tight and it takes a lot of patience at that point.&nbsp\\;\\\\\\; The brass metal is soft and will bend or break if you put too much force on them.&nbsp\\;\\\\\\; If you screw a screw into the insert&nbsp\\;\\\\\\;first and then turn slowly into the fairing you'll be better off. Make sure your alignment is correct also. The brass insert has a tendency to want to bend outward and off center
JayLo
Detailing
Jul 16, 2008 10:19 AM
Billydj
VRSC Models
Jun 30, 2008 09:17 AM
fbn ent
Jun 16, 2008 06:54 PM
Nellybelle
Jun 10, 2008 10:24 AM
