Spark Plug Wires
Old Jul 20, 2008 | 08:43 PM
avalauncher's Avatar
avalauncher
Default Spark Plug Wires
Though I have large hands, and a bit arthritic I suppose, they aren't enormous. That said, how do you change the spark plug wires without taking the gas tank off of the FLHTCU? And, please, don't tell me the tank must come off. Clearly, the spark plug end is a none issue but is there a trick to reaching up under the tank to take off the old ones and attach the new one?
Thanks is advance for any advice.
Old Jul 20, 2008 | 08:47 PM
blueflht's Avatar
blueflht
Default RE: Spark Plug Wires
loosen the rear bolt on the tank and ease it up should be enough to reach
Old Jul 21, 2008 | 12:30 AM
glens's Avatar
glens
I do not know specifically if there will be an issue, but you might want to make sure the new wires do not mess with the Ion Sensing system the bike computer uses to monitor ignition.
https://delphi.com/shared/pdf/ppd/pwrtrn/gas_ignics.pdf
Old Jul 21, 2008 | 12:48 AM
crzrdude's Avatar
crzrdude
I've changed them by removing all 3 bolts for the tank. Raise the rear of the tank&nbsp\\;as high as you can and place a block of wood between the frame and tank. That should give you enough room to change wires and/or throttle cables. Done it many times. Good luck.
Old Jul 21, 2008 | 05:17 AM
kyote's Avatar
kyote
I've just taken the front bolt out..was able to raise it enough to change the wires on the coil...
Old Jul 21, 2008 | 09:23 AM
2008FLHP's Avatar
2008FLHP
is there any real advantage to replacing them?...let me preface, of course if they not broken
Old Jul 21, 2008 | 09:29 AM
Bluesssman's Avatar
Bluesssman
ORIGINAL: 2003FLHPI
Depends on the condition of the wires. If they are cracked and arcing it would be a major necessity to replace them.
bigpappa160
EVO
11
Feb 23, 2016 03:17 PM
MIBPreacher
Mar 5, 2012 05:35 PM
jacknthebox
Sep 5, 2011 07:17 PM
strtarrow
Mar 3, 2011 07:59 PM
smokntitan@Gmail.com
May 28, 2010 07:01 PM
