PC3 Stage 1 vs. non Stage 1
Old Jul 24, 2008 | 12:42 PM
2008FLHP's Avatar
2008FLHP
Default PC3 Stage 1 vs. non Stage 1
after doing a map compare, it seems the Stage 1 is a little leaner...too save fuel, would it hurt to use a Stage 1 map on a non-Stage 1 ecu?
Old Jul 24, 2008 | 12:48 PM
garyhendley's Avatar
garyhendley
Default RE: PC3 Stage 1 vs. non Stage 1
i think you should be in the ignition/ timing section on this forum for the answers you need
ride safe
Old Jul 24, 2008 | 02:23 PM
2008FLHP's Avatar
2008FLHP
but but but, its on my touring bike!
Old Jul 24, 2008 | 11:44 PM
glens's Avatar
glens
ORIGINAL: 2003FLHPI
The Stage 1 PC map is a little leaner because the Stage 1 download adds fuel.
I would go with the proper map and remove a few percent fuel throughout the cruise range.
Old Jul 25, 2008 | 07:38 AM
2008FLHP's Avatar
2008FLHP
i was thinking that but the stage 1 map kinda does that already...basically its a little richer on the low end and leans out by a couple of points on the mid/high range, which for me is fine since i mostly ride highway...
i was just wondering if i would mess anything up by doing so, i dont think it would but i wanted to ask the experts...thanks
Old Jul 25, 2008 | 01:04 PM
glens's Avatar
glens
I would leave the mid/upper stuff where it needs to be, for the times you want to use it. If you go with a little less fuel there you might have to back off the timing, too.
Z
Jun 17, 2019 01:12 AM
rollin_thunder
Aug 6, 2010 12:39 PM
troop
Apr 1, 2010 10:01 PM
mike06train
Jun 30, 2009 04:52 PM
eagle1eye
Jul 13, 2008 04:52 PM
