Windex!!!
Old Mar 14, 2006 | 12:54 PM
Manish_Hawg's Avatar
Manish_Hawg
Default Windex!!!
If you are uncertain about anything all you have to do is ask this forum and someone will have input. It may not always be right or you may not agree with it, but you will get some input.
Well, I tried something without consulting the forum! [] What was I thinking? However it’s not too late. Responses will just let me know if I should do it again.
Sunday I went to this hang out and it’s awesome. About 40-50 bikes, people enjoying the fellowship and having a good time. There were bikes that were shinning like I have never seen before. I was going over to the guys to ask what polish they used and guess what I saw……………………………………… ……Windex! Yes you heard me Windex! They were wiping and spraying on Windex. They told me don’t use the old “blue” Windex, but the clear Windex with the yellow label. It’s ammonia free and has vinegar in it. I was told it won’t affect your paint because it is ammonia free and it doesn’t streak.
Yesterday, I washed my bike, dried it, and applied Windex to the paint, chrome, and everything. My bike looked like it should have been in a bike show. I’m thinking to myself, I can wax/polish every now and then but this Windex is cheap, last a long time and it’s the way to go. No more expensive stuff and I can pick it up at the Wal-mart on the corner.
Does anyone have an opinion on using Windex? I know the Harley Gloss can be used all over the bike and they sure smell the same. I’m not concerned about the chrome but more concerned about the paint in the long run.
Old Mar 14, 2006 | 01:09 PM
lil_gmac2's Avatar
lil_gmac2
Default RE: Windex!!!
I use windex on my chrome only. Any type of cleaner will make you bike shine especially glass cleaner.
Old Mar 14, 2006 | 01:17 PM
wingt50dw's Avatar
wingt50dw
Makes sense, we may be the only two DA's on this forum that never thought to use it but it sounds like a great quick spruce-up when there is no time for an intense washing and cleaning...I used to use pledge furniture polish on my bass boat after taking it out of the water and wiping it down, something I did everytime I took it out of the water...Always was clean with an awesome shine and very rarely needed polish...Sounds like the windex is the same principal, just a different chemical on a different surface. I am going to get some today because I have very little time to do a regular full cleanings on my scoot because I ride it when I am not busy working!
Old Mar 14, 2006 | 01:24 PM
sleepman54's Avatar
sleepman54
I've used glass cleaner on my chrome for a long time now. It's easier to use then applying chrome polish and I think it gives a better shine. Haven't used it on the paint however.
Bruce00's Avatar
Bruce00
I sure it will make it shine, but is it protecting the paint/chrome? Not a flame, but curious. And does it strip the wax off?
If it works for you great! But I think I'll still do the old method of waxing
Old Mar 14, 2006 | 01:35 PM
Manish_Hawg
Right I plan on using the old method of waxing every 4-6 months (Zymol), but it seems after every wash I could use Windex to keep the shine as opposed to other agents.
Old Mar 14, 2006 | 01:46 PM
dja1340's Avatar
dja1340
Protect-All is the only way to go. Windex for the bugs and grime, then Protect-All. Has carnuba wax and other additives. Good for everything accept the windshield.
Old Mar 14, 2006 | 01:47 PM
RenoGlide's Avatar
RenoGlide
Windex w/ vinegar is good for chrome & metal but should not be used on any waxed surface...why?... if it will remove greasy fingerprints off chrome then you can be assured it will remove wax too. Vinegar is basically a mild acid with a pH of about 3.0, comparable to lemon juice, where battery acid is 0 pH...windex has a pH of about 10.
A heavy wax coating is about .001" (1/1000) thick after polishing. In comparison a sheet of notebook paper is about .003 (3/1000) thick. Fresh wax can be removed from a painted surface by applying a hot sweaty palm ( pH of 5) for a few minutes...
A better choice for paint would be any brand of detailing wax ... Mothers, Turtle, Meguires, etc.
Or my choice... dont worry about it ... Ride more, Clean Less
RenoGlide
www.FastAire.com
Old Mar 14, 2006 | 01:57 PM
MDMYMD's Avatar
MDMYMD
I also use windex or similar on my chrome parts and windshield/signal lenses. I would be concerned about the long term effects on the paint. There is not much paint on our bikes, so I stay with the tried and true periodic waxing. Once clean and waxed, I maintain the shine with the HD spray cleaner/polish. Maybe not the best, but it sure works with my paint (rich sunglo blue).
Old Mar 14, 2006 | 02:18 PM
onephsyco1's Avatar
onephsyco1
I've heard using pledge is great !
Jack
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
