Hard to shift when warm/hot
Old Jul 30, 2008 | 11:55 AM
Xguy's Avatar
Xguy
Default Hard to shift when warm/hot
when hot like after a while of riding, it becomes a bit clunky and harder to shift,
Old Jul 30, 2008 | 11:59 AM
Xguy's Avatar
Xguy
Default RE: Hard to shift when warm/hot
nothing un-ridable just&nbsp\\; ruff and a bit noisy (I can hear the chain almost), is this normal?
Old Jul 30, 2008 | 12:24 PM
McSporster's Avatar
McSporster
Mine is the same ('01 RKC) some of the time.&nbsp\\; Just a&nbsp\\;bit stiff when shifting down.&nbsp\\; It seemed better when I had "regular" HD dyno fluid in it, which I had&nbsp\\;changed to (...following the HD recommendations) when I bought the bike.&nbsp\\; I've noticed that the drained fluid has the smell of auto differential fluid, so maybe that was what was in it before...and, should be again?&nbsp\\; I'm trying HD's SYN3 now, so we'll see how that works.&nbsp\\; Mc
Old Jul 30, 2008 | 01:36 PM
TMART's Avatar
TMART
Put Amsoil 75w-90 severe gear in it,this is some magical stuff.
Old Jul 30, 2008 | 01:40 PM
PTAG's Avatar
PTAG
Amsoil in all 3 holes and you will be surprised at the difference
Old Jul 30, 2008 | 01:45 PM
rwagon57's Avatar
rwagon57
Adjust the clutch.&nbsp\\; You probably don't have enough freeplay in the clutch push rod.&nbsp\\; Adjust cold by turning the adjuster in until all play is lightly taken up, then back off 1/2 to 1 turn, and tighten lock nut.&nbsp\\; Then adjust cable.
Old Jul 30, 2008 | 01:47 PM
carpetride's Avatar
carpetride
just wear some stronger soled sandals and KICK that bitch.
Old Jul 30, 2008 | 02:30 PM
Xguy's Avatar
Xguy
ORIGINAL: PTAG
3 holes? primary, tranny and ?
Old Jul 30, 2008 | 02:40 PM
ngoti8tor's Avatar
ngoti8tor
ORIGINAL: Xguy
ORIGINAL: PTAG
Engine&nbsp\\;
Old Jul 30, 2008 | 03:05 PM
TMART's Avatar
TMART
some run amsoil 20-50 advance formula motorcycle oil in all three holes,I run it engine and primary and the amsoil 75-90 severe gear in the trans.great combination.Mine is an o7 and i dont hear any trans whine that these things are famous for with the severe gear in it.
