Instructions Needed? Side Light Kit (King Tour)
Old Aug 10, 2008 | 05:55 AM
jcbpa's Avatar
jcbpa
Default Instructions Needed? Side Light Kit (King Tour)
This may solve my problem... if someone has this can you send me a pdf?
Instructions for 53457-79C
thanks,
J
Old Aug 10, 2008 | 06:20 AM
Drew's Avatar
Drew
That's the wrong kit, if you're putting it on your '08. The tour-paks were redesigned for 2006, and the kit you need is 69494-06.
Attached Thumbnails Instructions Needed? Side Light Kit (King Tour)-69494_06_m_1e83f.jpg
Old Aug 10, 2008 | 06:30 AM
xcelr8's Avatar
xcelr8
Correct. I ujust installed the kit on my '07 EGC. The differance is the old one is straght and the newer one is wraparound. Took me 15 minutes to install and another hour to figure out (and fix) that they were wired backwards.
Old Aug 10, 2008 | 07:05 AM
Harleypingman's Avatar
Harleypingman
Just ask the guy at the parts counter of your local HD store to print out the instructions from the kit you need. Takes all of 30 seconds.
You may also need the connector to plug into the Tour Pak wiring harness on your bike and the wire terminals (pins or sockets). You can buy these, if you need them, from the HD store by getting the part numbers from the Touring parts book.
Good luck with your project.
Old Aug 10, 2008 | 07:08 AM
jcbpa's Avatar
jcbpa
Anyone know what size hole to drill? HD closed around here on Sunday. Thanks, J (To allow the new wire entrance to the inside of the tourpak?)
Old Aug 10, 2008 | 08:29 AM
soos's Avatar
soos
thanks,
J
Ask the dawg.
varider12$
Jan 15, 2017 10:12 AM
joe mayo
Mar 17, 2013 03:07 AM
rdc401
Apr 6, 2012 09:27 PM
glide2meetu
Jun 19, 2011 09:05 PM
riconot
Feb 23, 2008 09:29 AM
