IDS - outer bearing failure
Old Aug 10, 2008 | 03:50 PM
RangeRat's Avatar
RangeRat
Default IDS - outer bearing failure
'07 RK with IDS add-on...
Don't know for sure what has happened but I can see that the outermost dust shield is sheared with about 1 inch or so of the thing sticking out. It made an intermittent but pronounced "klack" at low speed and no load but for some reason was quiet at speed. Pulled over, popped off the L/H saddlebag, and there is was - broken end twisted up a little but sticking out far enough to whack against the swingarm once in a while.
I can't feature the dust cover snaping all by itself so I guess there's some sort of hard bearing failure too. It's under warranty so we'll see and I'll update later next week.
Old Aug 10, 2008 | 04:33 PM
Plow64's Avatar
Plow64
Pics?
Old Aug 10, 2008 | 07:21 PM
RangeRat's Avatar
RangeRat
I'll try to get one tomorrow when I'm dropping it off at the dealer. In case I can't, (and if I'm correct that this is a like some needle bearings I've seen), the shield is a narrow steel washer looking thing that is real skinny and just fits into the bearing cup - between the rollers and a machined ridge in the bearing cup.
I think the idea is to keep lube in and dirt out. Hopefully someone here on the forum knows more than I do and I'll know more soon myself but that's what it looks like to me anyway.
Old Aug 10, 2008 | 07:39 PM
tjmac49's Avatar
tjmac49
That blasted IDS sure has had its issues. Good luck, RangeRat!
Old Aug 26, 2008 | 02:46 AM
RangeRat's Avatar
RangeRat
Default Status
Slow going so far but my dealer contacted MoCo yesterday trying to figure out what's up WRT IDS bearing failures. Will update when I know more.
Old Aug 26, 2008 | 04:47 AM
XTrooper3936's Avatar
XTrooper3936
I've been following this issue closely and I've noted that virtually all the IDS failures involve those retrofitted on 2007 models while the 2008 factory-installed units have been rock-solid reliable. To me, this indicates either some yet to be identified incompatibility or improper installation. I hope they get to the bottom of it for you.
Old Aug 26, 2008 | 04:55 AM
Sefferdog's Avatar
Sefferdog
Hey RangeRat, just curious how many miles do you have on the IDS? Thanks.
Old Aug 26, 2008 | 06:46 AM
sparky_mo's Avatar
sparky_mo
RangeRat. Was wondering if you bought it through your dealer and if they originally installed it for you?
Old Aug 26, 2008 | 06:49 AM
Dalton's Avatar
Dalton
I have about 20000 miles on the IDS I installed with no issues so far, but have been keeping an eye on it.
Old Aug 26, 2008 | 09:14 AM
HarleyWood's Avatar
HarleyWood
Hmmm...I wonder if this is why they put this little note in the '08 manual..
The compensator sprocket bearing has a split inner race that requires proper compression. Deviation from the following procedure may lead to premature bearing failure.
17. Holding weld nut on lefty side of axle, proceed as follows:
a. tighten cone nut to 95-105 ft lbs
b. loosen cone nut one full turn
c. retighten cone nut to above specification
