Chubby 518s and long distance
Old Aug 11, 2008 | 11:13 PM
seantx's Avatar
seantx
Default Chubby 518s and long distance
I'm really wanting a pair of the 518s for my 06 RK Classic. My main concern is that I don't want to compromise the general "comfort" of the bike for long distance. I have long arms but the stock bars make me lean forward slightly. If I watch my posture this isn't a problem. But it seems that if my arms were back a little more toward me and out slightly it would help...not to mention they just look cool.
My question is for the guys that have these. Do the 518s help or hurt for spending long days (500 miles or so) riding? Also did you use +4" throttle/idle and brake cables or make due with stock?
Thanks!
Old Aug 12, 2008 | 12:10 AM
BadBoyFLSTC's Avatar
BadBoyFLSTC
I would also be interested in the answer to this.
Old Aug 12, 2008 | 09:16 PM
seantx's Avatar
seantx
Shameless bump for my own thread....
Old Aug 12, 2008 | 09:57 PM
Hobe's Avatar
Hobe
I ran them on a fatboy and found them to be great, I still miss them. I used the stock cables and had to straighten out the brake line, always planned on changing the contols out but never got around to it before I swapped it off.
Old Aug 12, 2008 | 10:03 PM
Whiskers's Avatar
Whiskers
I have them on my RKC and really like them. My biggest problem is that I need a backrest...without it I still get sore and I don't think its the bars fault. Whenever I've carried a pack and had a place to lean back on the bars have really been a blessing.
Old Aug 12, 2008 | 10:06 PM
SoCal_Pappy's Avatar
SoCal_Pappy
518's ARE MUCH better then the 508's and Way Better then the OEM... (Have them on my 01 RKC (508's) and my Sons 05 RK (518's)
Old Aug 12, 2008 | 10:13 PM
redhwk44's Avatar
redhwk44
I have put over 12000 miles on my 518s(about 14 months of riding) and I can honestly say they are awesome. Last year I put 4900 miles on in 10 days and they are head and shoulders over stock bars. I believe I used the stock clutch cable length but had to go with +2" on the throttle , idle and brake line. Unless you want to bend and stretch your lines. You cannot go wrong with Wild1s or 518's. they will improve your riding experience beyond what you believe possible. Jeff
Old Aug 12, 2008 | 10:24 PM
seantx's Avatar
seantx
Thanks guys. Sort of confirmed what I thought already.
Old Aug 12, 2008 | 10:47 PM
nb472's Avatar
nb472
518's are great for the long hauls. I have a back rest, sundowner seat,air hawk cushion and justed added floorboard extensions from site sponsor. Bike feels like a easy chair.
Wild one says everything will work with stock cables,and wiring, but I did'nt like the look and really doubt if it would be very easy to do.
I went with the Magnum Chromite cables,they're beautiful. Went 3" over on the throttle ,idle,brake and stock on the clutch. Worked perfect. Check they're web site, they make it easy. Extended all 18 wires 4" (should have went 5") and ran them in the bars. Time comsuming job, but worth it.
518's strong point is the comfort on long rides and they're beautiful. They can be an bit awkward on slow tight turns, but you soon get use to them.
If you're interested in tackling a job like this and need help, send me a p.m.
Old Aug 12, 2008 | 11:27 PM
bbissell's Avatar
bbissell
I will be putting my 518's on this sat. When i ordered them from wild1 they said i needed +4 on the throttle,idle and a stock clutch works fine. I cant wait to get them on there. I also ordered the wire extension kit. I ordered all of that at www.johnnyvaughn.com. Those are some very nice bars they arrived here yesterday!
