Do I "need" a fuel manager?
Old Aug 11, 2008 | 11:22 PM
spizzyman's Avatar
spizzyman
Default Do I "need" a fuel manager?
I just bought my Ultra, used. It has SE slip ons and a K & N filter behind the football. It runs well and does not seem to have a heat issue with no fuel manager. The dealer thinks the set up is fine and has done all maintenance on the bike from new.
Am I good to go or is there anything to be concerned about? The motor is stock, has plenty of get up and go and only 8500 miles on it.
Since this is my first Harley, any advice would be appreciated.
spiz
Old Aug 11, 2008 | 11:27 PM
Emporers New Clothes's Avatar
this set up should be fine as long as it's had downloads from the dealer which it sounds like it has
Old Aug 11, 2008 | 11:30 PM
spizzyman's Avatar
spizzyman
Yes it has had the download. I forgot that part.
Old Aug 12, 2008 | 03:42 AM
kgjl's Avatar
kgjl
If you are pleased with what you have, don't screw with it!
Old Aug 12, 2008 | 03:52 AM
Bossman1's Avatar
Bossman1
Should be gud to go!!!!!!!
Old Aug 12, 2008 | 05:17 AM
hogrider98's Avatar
hogrider98
is there more than 1 poss download as I bought mine used also with k and n
and rineharts it pops through the exh on decell or between shifts.
sorry about the high-jack
Brian
Old Aug 12, 2008 | 05:39 AM
biz44's Avatar
biz44
Brian
Not all bikes are the same.....yours may have some issues with decel popping, and your riding bud's with almost the same setup dont. Things like that require time to sort out. While some dyno tech use canned maps.....others only use the canned map as a starting point, and then work on specific areas to give better MPG or more torque at a certain RPM fir instance.
Its my understanding that the MOCO's "stage-1" download dont do much in some cases and nothing at all in others.
Spizzyman......on your bikes football....is there a backing plate that encloses the K&N, or is the back of the football open exposing the K&N filter to the air? If its all closed up then chances are the K&N is just whats called a "drop in" filter used just to replace the OEM paper (non reusable type). The drop in units from K&N can be cleaned and re oiled many times.
Now if the back of the football is open.....you may have a modified intake with a K&N that has a larger surface area, allowing the bike to breath better = more air. Now the slip ons will let the exhaust system to move more air, but not as much as a true dual system with tuned header pipes.
If your running just a drop in filter and a set of slip ons, you dont need a fuel management system, but the engine would perform much better with one. If on the other hand you have a modified intake/air filter, and a set of high flowing slip ons.....but still with no fuel management system. In that case I would at the very least do a "plug chop" test, and see what your plugs are looking like....you could be running too lean. In any case, I would install a fuel management system, like a PC-III, or SERT....then have it fine tuned on the dyno by someone that knows what end of the screwdriver to hold.
All this is assuming you have a FI system and not a carburetor.
Old Aug 12, 2008 | 06:45 AM
spizzyman's Avatar
spizzyman
Fuel injected, no backing plate. They described it as "heavy Breather kit" I believe. As much as I have tried to absorb on the board, I find there is much I do not know, coming from the liquid cooled metric side. Pleas describe the "plug chop test". I am going for a ride this weekend and don't want to risk anything.
spiz
Old Aug 12, 2008 | 06:54 AM
SoCal_Pappy's Avatar
SoCal_Pappy
On a '03 you shouldn't have a heat issue like the '07's+. If you had the stage 1 download and you're NOT having any problems with its running & your spark plugs look good... Just drive the snot out of it and enjoy.
scooter_nate
Apr 18, 2014 01:15 PM
tht1124
May 20, 2009 09:29 AM
wildeano
Oct 8, 2008 01:18 PM
ebolafever
May 17, 2008 03:06 PM
LarryJ00
Jun 12, 2007 01:06 AM
