Lowering Kit for FLH Touring bikes
Old Jan 25, 2010 | 05:41 PM
EasyriderFI's Avatar
EasyriderFI
I just saw a lowering kit in the Bagger Mag. It lowers the rear 1inch. Its called Pingel and I should be able to install myself.
Old Jan 25, 2010 | 05:56 PM
Firetender's Avatar
Firetender
I'm still looking for a "raising" kit for my FLH. There's no such thing as too much lean angle!
Old Jan 25, 2010 | 06:02 PM
lrays280z's Avatar
lrays280z
Will those work on RK Classics? I've seen some on eBay that said that they would not work on RKCs because of something about the stock leather bags???
Old Jan 25, 2010 | 06:41 PM
jag1886's Avatar
jag1886
I tried the cheapy lowering kit to start with and found it bottomed out quite regularly even with the shocks full and I only weigh 200lbs, I replaced them with shorter Progressive air shocks and no more problems.
Old Jan 25, 2010 | 08:27 PM
revelator2's Avatar
revelator2
the way you can run those on a RK classic with leather bags is....you have to drill out the rivets on the rubber cushions on the bottom of the bag....then move them toward the INSIDE of the bag about a half inch and redrill and bolt them back on. I used 8-32 screws and nylok nuts. It works...road this way for 2 years.
Old Jan 25, 2010 | 09:32 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
I have the road6customs kit on my 05 FLHT (middle setting) and on my 09 SG (1st setting). I ride 2-up 50% of the time and have NO issues with the kit. I routinely make sure I have enough air in the shocks especially when we're going on a trip with extra stuff piled on.
Dave
Old Jan 25, 2010 | 09:46 PM
Johnny Wolf's Avatar
Johnny Wolf
Dave
I have the kit as well, but haven't installed it yet on my '03 FLTP. Three questions:
Did you lower the front?
If not, how did the handling change? I ask because if you only lower the front, it changes the rake on the forks.
If not, did you have to re-aim the headlight/spots?
I apologize for so many inquires, but I'm new to touring models.
Many thanks,
JW.
Old Jan 26, 2010 | 02:07 PM
EasyriderFI
Default The lights
I never thought about the lights. I plan to lower the rear 1inch but still that raises the angle of the light up or further down the road
Old Jan 26, 2010 | 02:29 PM
Johnny Wolf
yep, hence my inquiries
Old Jan 26, 2010 | 11:13 PM
EastSideBikerTrash
I did not lower the front or have to adjust the headlights. IMO, handling is much improved especially at low speeds. I don't have any problems bottoming out or scraping and I ride pretty hard sometimes.
dave
Many thanks,
JW.
