High Speed Wobble...When?
The rear sway is another issue completely. I find that using a low gear instead of brakes in a curve as well as using steering input without leaning into a turn will allow the bike to lean over more and makes it more stable on a curve. This is only to the point of scraping the floorboards at which point it is recommended to either slow down or lean. However this does not seem to impact stability where the bike already has enough lean angle.
A lot of people are overloading their bikes and stacking weight up high which makes it worse.
If you have never scraped a floorboard going around a sharp turn your not driving fast or your leaning over. I put a bell on the right floorboard bracket so I know when I have reached the maximum lean. You can hear the bell ringing. The left turns are not as tight so they are less of an issue. Maybe I will get two bells. My right one is wore down pretty bad.
05 FLHR 89,000 miles. Photobucket.com/OneHorseRally
Rode 14000 this year. Appalacian mountains and Laconia Motorcycle Rally. The second trip was Lake Michigan, Lake Superior, Harley Museum, Hwy 2 out to Glacier and down. Over to Sturgis for the Rally. Both trips origiating on the Gulf Coast. Pictures from these trips will be uploaded soon. No albums from 2011 on OneHorseRally yet.
Your FLT was one of the first rubber-mount touring models IIRC, from which all others were developed and uses the same system. So it also has the unsupported rear mounts that a stabilizer can provide an improvement on.
the weight of the bike to one side is really helping or exaggerating whatever
causes the oscillations to begin with.
My opinion is there are a couple different issues that may help or contribute
to the problem. Wind and the batwing, tires, steering head issue, and of
course the frame design and bushings.
As a earlier post pointed out not to hard to see wind induced oscillations
by just taking hands of the bars.
Additionally, although less common you can get wobbles just going
straight and much slower than 70-80. I personally had it once at around
50mph. So one size doesn't fit all.
Many people never see the issue so riding style certainly plays a part too.
Thanks that answers the question, I will be looking at stabilization for the insurance.
Guess I should have mentioned that is shock presure not tire.
Cheers
As Howard at HDF sponsor Motorcycle Metal taught me, springs hold up the weight of the bike and riders, while the internal damping keeps the ride and bumps under control. With fully adjustable Ohlins, courtesy Howard, the ride height can be correctly adjusted with the springs, and the damping fine tuned, to achieve nirvana.
