08 - 09 Tour Pak
Old Aug 16, 2008 | 08:08 AM
hoz88's Avatar
hoz88
Default 08 - 09 Tour Pak
I noticed the 09 P&A book has a different part number for tour paks on the 09 bikes. My plan was to keep the pak off my 08 RG and put it on my 09 SG, but now I am starting to wonder if I can. I know the docking points are different and I will need a new rack, but will the 08 pak bolt on to the 09 rack? Thanks.
Old Aug 16, 2008 | 08:27 AM
Harleypingman's Avatar
Harleypingman
Given the wider fender (which necessarily widens the mounting points; which necessarily widens the bolt locations for attaching the box to a rack), I doubt that it will be a simple swap. I'd check the bottom of the tour pak at a dealership on an '09 and see if the bottom is shaped to fit the wider bolt hole pattern. If it is, then you would have to decide is you wanted to drill your current box to create new holes for mounting.
Just my .02.
Old Aug 16, 2008 | 09:29 AM
mrbuck's Avatar
mrbuck
i'm not 100% but i think it'll work like pingman said you may need to drill a new set of wholes, the boxes are the same
Old Aug 16, 2008 | 11:31 AM
hoz88's Avatar
hoz88
That was kind of what I figured just looking at an 09 Ultra, but just wanted to see if anybody had personally done this. I would sell my 08 Candy Red Sunglow pak and just buy one to match my new SG if anybody is interested.
Old Aug 16, 2008 | 12:00 PM
Garemlin's Avatar
Garemlin
Wow that really sucks that they changed the tour pak as well as the rack and docking hardware. That is one big item that you can't take with you when you trade.
Bigbird
Dec 9, 2013 06:02 PM
botlefedpony
Apr 25, 2010 09:54 PM
springer 03
Mar 17, 2010 09:49 AM
hawkeye85
Dec 17, 2009 07:54 PM
fonemann
Aug 10, 2008 08:33 PM
