Drag Pipe Conclusions
Old Aug 17, 2008 | 07:55 PM
txfxstrider's Avatar
txfxstrider
Be interested in what you think of them running torque cones but no baffles. I had good results doing that on an evo which I think needs more back pressure than a TC.
A little decel popping is not hurting anything. And it does sound good.
Old Aug 17, 2008 | 08:50 PM
bigbrokah's Avatar
bigbrokah
Yeah, the torque cones will be the next experiment, but it'll probably be a few months though. The less time I spend turning wrenches in my garage in this San Antonio heat the better!
It should take a lot less time to just throw in some torque cones. Even though it's only been a few days I already miss the unbaffled rumble... I'm talking myself into doing this sooner than I thought....
Old Aug 17, 2008 | 11:12 PM
tmitchellof PG's Avatar
tmitchellof PG
My drag pipes work fine with just power cones(torque cones). I have the 103" engine and the pipes are only 1-5/8" ID. The smaller ID drag pipes work better.
One cheap trick you can try is putting lollipops in the pipes. Bolt them in at the baffle attach holes. There is a good write up in the sticky part of the "Exhaust Section" on "how to with Drag Pipes". It tells you how to make up the lollipops. You can also just put a long bolt in the hole where the baffles attach. The bolt should span across the ID of the pipe. Use a nut on the inside to hold the bolt in place. This alone will give you back some back pressure to help in low and mid range torque.
Tom
Foxster
Apr 6, 2012 10:28 AM
Gladiator72
May 18, 2010 11:58 PM
WillieC
May 28, 2009 04:57 PM
jmxp
Jul 23, 2007 07:38 PM
waterman7474
Exhaust System Topics
Nov 28, 2006 12:46 AM
