Bike shut down while passing semi
Old Aug 18, 2008 | 09:10 AM
acchd's Avatar
acchd
I've heard a flakey intermittant ignition switch can cause that. If you have a ohmmeter might want to check the switch.
Old Aug 18, 2008 | 10:16 AM
chiefordnance's Avatar
chiefordnance
Try checking the rev limiter if she's fuel injected it shuts stuff off like the fuel pump. Factory is like 5800rpms and the stage 1 moves it to 6200rpms.
Old Aug 18, 2008 | 10:38 AM
Sharknose's Avatar
Sharknose
Originally Posted by thumperhumper
... and the lovely wifey is sayin "NOW WUDYA DO".
Don't you just HATE that....
Old Aug 19, 2008 | 04:09 AM
thumperhumper's Avatar
thumperhumper
Thanks for all the replies folks. I'll check my connections at battery and ground to see if they are tight.
I know the bike is low miles and yes I bought it 11 months ago with 6700 miles so I'm not doing too bad am I?
I did install the HD fog lights on the crash bar about 2000 miles ago. I tapped into an aux. 15 amp lead under the fairing and it is unswitched so on all the time. Could this be the problem?
Old Aug 19, 2008 | 04:31 AM
Bad Pig's Avatar
Bad Pig
+2 on that! like "well dear I'd see what it would be like to almost crash with a semi in the mountain wilderness" lol
glad you saved it!
Old Aug 19, 2008 | 06:22 AM
Andy Engemann's Avatar
Andy Engemann
I had a carbureted 99 RK that would consistently shut down whenever I accelerated heavily through 3 or more gears, usually from a dead stop. Each time it did it, I thought it seemed like it was running out of gas! I would roll to a stop, wait 30 seconds or so and it would re-start fine. I replaced the stock fuel valve with a hi-flow Pingel valve and it never did it again. My stock valve may have been defective since the fix didn't seem to make sense.
Hope you get it solved!
Andy
Old Aug 19, 2008 | 06:33 AM
Sodiee's Avatar
Sodiee
+1 on the rev-limiter.If you ever get your RPMs up high enough,the rev-limiter will kick in and your bike will have no power.Pull over and get the bike back to idle and it should be good to go again.You can also upgrade you ignition that will put your RPM rev-limiter at a higher RPM(or remove it completly).
Greezey Rider
Jul 6, 2016 09:31 PM
Swamp Tiger
Dec 29, 2015 05:26 AM
goallight
Jun 29, 2013 11:48 PM
manuel_hero
Aug 3, 2012 09:33 AM
S7GraveDigger
Jul 28, 2010 09:32 AM
