Where to wire left switch on a RKC?
Old Aug 23, 2008 | 08:12 PM
Lil3rdSt's Avatar
Lil3rdSt
Default Where to wire left switch on a RKC?
I just got my Streetpilot 2820 kit to wire to my '08 FLHRCi and I wanted to hook it into the spare left switch (the oposite that powers the front lamps). I thought I had read somewhere that there was an extra feed/input down by the battery that this left switch powered.
I just took off the set, ECM, and covers, I'm at the battery, even see another wire with a 7.5amp fuse on it, but I can't find where the wire terminates or where I could wire the GPS power to.
Any assistance of where to look I would love. I would much rather run the power off the switch instead of hard wiring to the battery.
Thanks!
Old Aug 24, 2008 | 06:02 PM
jdeitrick's Avatar
jdeitrick
There is a 4 pin deutsch connector in the v-shaped hollow between the battery and the gas tank. You still need the mating connector with wire running to your device. It is on the accessory circuit, so the ignition has to be switched on (or to accessory) and the accessory switch on the fairing cap has to be on.
Old Aug 24, 2008 | 06:46 PM
JGroves's Avatar
JGroves
It is located right where you are looking... keep digging.
ADVNTR
2014-2024 Touring Models
Apr 21, 2014 04:57 AM
Terrific Pacific
Feb 12, 2010 10:20 AM
RonH
Jan 21, 2008 04:32 PM
tbradley
Oct 2, 2007 01:15 PM
gordo 2050
Sep 3, 2007 02:05 PM
