Throttle cable lubing ????
Old Aug 27, 2008 | 04:52 PM
miacycles's Avatar
miacycles
When you do the clutch take the end out of the clutch handle spray some down there then open up the adjuster until it comes apart and spray some down there too. Then put it together and adjust the free play.
Old Aug 27, 2008 | 04:58 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Originally Posted by mduggan
On behalf of all 08 and 09 bagger owners everywhere, let me be the first to say Yeahhh, a thread about a throttle problem that doesn't involve TBW. But seriously, I'd try lubing and working the cable. If it doesn't work itself out in short order, you'll feel better if you go ahead and replace the cable. It sounds like the cable is binding internally, maybe on a frayed strand.
This shows the virtue of simplicity, something the MOCO is forgetting. Both TBW and cable throttles are subject to problems, but cable problems are a DIY easy fix. KISS!
Old Aug 27, 2008 | 05:45 PM
earlehd's Avatar
earlehd
I had this happen when I changed grips. I put everything back on a little too far. Grip would drag occasionally on bar on inside, back grip off alittle, everything is fine.
1flhtk4me
Jul 7, 2011 06:45 PM
global force
General Topics/Tech Tips
Aug 2, 2009 09:34 AM
masterblaster
Jun 25, 2007 02:07 PM
iasporty
Jun 19, 2007 12:23 PM
Wally
Sep 1, 2006 01:24 AM
