Broken Brackets
Old Aug 29, 2008 | 09:59 PM
Getyurmotorunnin's Avatar
Getyurmotorunnin
Default Broken Brackets
I had my front faring off this weekend to fix a couple of broken wires and I notice that the support brackets were broken in 6 places, 3 on each side. I have heard of this happining a lot but what if any is the Motorco doing about this. I cked the price and it looks like to replace the brackets would be around 120bucks. Does any one know it the motorco is doing any thing about the broken brackets?
Old Aug 29, 2008 | 11:22 PM
Bill03E's Avatar
Bill03E
MOCO will replace them under warranty if your bike is sill under warranty, if not ,do what I did, and weld them up so it does not happen again.
Old Aug 30, 2008 | 09:15 AM
blueflht's Avatar
blueflht
take the time to check your front motor mounts. broken mounts are the main cause for fairing bracket failures
Old Aug 30, 2008 | 09:38 AM
Harleypingman's Avatar
Harleypingman
I asked one of guys at the parts counter to check the part nos. for the fairing support brackets on the '09's to see if they are new; he checked the parts book and told me they are the old part nos.--not new ones.
Old Aug 30, 2008 | 09:54 AM
DamifIknow's Avatar
DamifIknow
This happen tp me as well. I bolted some angle brackets to them for support.
Old Aug 30, 2008 | 10:20 AM
rabidd's Avatar
rabidd
Is there away to check the brackets with out taking everything apart 07 ultra 11000 miles.
Old Aug 30, 2008 | 10:24 AM
dgriffith's Avatar
dgriffith
Time to bring out the welder and shop skills to weld and reinforce the HD flimsy brace. By welding them back together, you will see where a brace or thicker material is needed. In the case of my main braces on the Ultra. The ends were broken off. After welding them back on, I bent a J shaped piece of material and made a complete pocket brace around the whole thing. Fixed forever.........probably brake somewhere else.
Old Aug 30, 2008 | 10:27 AM
GGC's Avatar
GGC
You'd think one of the aftermarket outfits would come up with a fix for this obvious problem!
Old Aug 30, 2008 | 11:43 AM
dawg's Avatar
dawg
PM "fryeca" here on the forum. He redesigned the brackets somehow and was going to start making and selling them, but I don't know if he ever did. Here's a pic of what he made to accompany the stock ones
Old Aug 30, 2008 | 03:31 PM
GGC's Avatar
GGC
Looks simple enough!
