Is it normal? (brakes)
Old Aug 30, 2008 | 11:11 AM
spizzyman's Avatar
spizzyman
Question Is it normal? (brakes)
for the front brake pads to slightly touch the rotors when not actively braking? I can hear it at slow speed (like in the driveway) but when I slightly pull the front brake it goes away. I have checked the life of the pads and they look good, although the right side seems to wearing a bit faster than the left. I have ridden the bike at speed for hours at a time with no perceived ill effects. My VTX did the same thing from new, so I have not thought it strange until just now.
Advice?
spiz
Old Aug 30, 2008 | 11:16 AM
SgtThump's Avatar
SgtThump
My RK does the same thing. I asked a friend and he said his EG did it too. I "think" it's normal?
Old Aug 30, 2008 | 11:28 AM
robbie52's Avatar
robbie52
Normal to hear slight rubbing when moving around in the garage.
Old Aug 30, 2008 | 11:39 AM
Intrepid175's Avatar
Intrepid175
Yes, it's normal. The old style drum brakes had springs that retracted the brake shoes away from the drum when the brakes were released. Disk brakes don't work that way. You apply the brakes and the pads squeeze the disk but there are no springs or anything else to pull the pads away from the disk when the brakes are released other than the action of the disk itself turning between the pads. Normally, it's not anything you'll notice but as you've discovered, you can sometimes hear it at slow speeds. It's nothing to be concerned about.
FWIW!
Ride Safe,
Steve R.
Old Aug 30, 2008 | 12:01 PM
Chicago Spike's Avatar
Chicago Spike
All disc brakes drag a little. As said, there is no retraction springs on discs. Your cars and trucks do the same thing, you just can't hear it unless you leave the car engine off and push it around
ISP-FLHTK
Jan 9, 2017 08:38 PM
see22ds
Jun 23, 2014 01:27 PM
don g
Aug 17, 2011 02:43 AM
fixedmlc
Aug 25, 2009 11:11 AM
JosephGarcia
Nov 15, 2007 10:46 PM
