Harley fog lights
Old Aug 30, 2008 | 05:39 PM
screws4156's Avatar
screws4156
Default Harley fog lights
I'm thinking about getting the HD fog lights. Are they adjustable? The pic makes them look fixed. Al so I could use a few ideas on locating them since I have fairing lowers on and don't plan on taking them off.
Old Aug 30, 2008 | 05:44 PM
cgonzgo's Avatar
cgonzgo
You can mount them where ever you want on the crashbar and they do rotate. I cant see making them work with the lowers though. Look at moto lights maybe....
Old Aug 30, 2008 | 05:59 PM
masterblaster's Avatar
masterblaster
Kury makes some lights that bolt to the fender mount. Dont know much about them but looking for the same thing.
Old Aug 30, 2008 | 08:29 PM
Sodiee's Avatar
Sodiee
I have them on my bike and you can adjust them but I don't think they'll work with lower fairings.Here's how mine looks:http://s270.photobucket.com/albums/j...t=DSC01808.jpg
Old Aug 30, 2008 | 11:04 PM
Harleypingman's Avatar
Harleypingman
1. The part of the fairing lower that covers the upper part of the engine guard will have to be cut-off to mount HD fog lamps with fairing lowers on the bike (IMO). And even if you did that, the fog lamps would be so far inboard that they'd light the back of the front fender and little else.
2. The fog lamps clamp on to the engine guard, but they do not pivot left/right; only movement is up or down along the axis of the engine guard. The fog lamp mounting is so thick, there is no way that it could be mounted on the vertical portion of the engine guard with fairing lowers installed IMO--the space between the fairing lower and the engine guard is too narrow for the fog lamp mount.
3. I removed the HD fog lamps when I installed fairing lowers and replaced the lighting with Motolights--an outstanding, though pricey, alternative.
Motolights with fairing lowers:
http://
HD fog lamps and Motolights:
http://
Old Aug 30, 2008 | 11:45 PM
screws4156's Avatar
screws4156
thanks for the input guys. I agree the moto lights are the answer execpt they mount to the brake caliber. I got caliber covers on my bike, so that won't work either.
I think if I munt them next to the hi-way pegs they will fit. I need to think on it a little. Kury is coming out with some lights that will replace the turn signal on the fairing I have to wait and seehow they look.
Thanks again.
Old Aug 31, 2008 | 12:27 AM
Born2Glide's Avatar
Born2Glide
I would like to get some as well. I have an auxiliary switch not being used and was thinking it would be good for the fogs, any one know how to tap into it.
Old Aug 31, 2008 | 12:41 AM
sifularson's Avatar
sifularson
I wonder if these will work with the lower fairings?
http://www.kuryakyn.com/products.asp?bn=harley&ci=3915
Steve
Old Aug 31, 2008 | 12:43 AM
LVRider's Avatar
LVRider
Smile
http://
http://
I really like the way those look.. I am looking to do the same on my '07 Ultra.. Did you look at the PIAA lights or were you set on MOTOLIGHTS?
Old Aug 31, 2008 | 02:02 AM
Joker441's Avatar
Joker441
I put some Kuryakyn small spot lights on my 04 Ultra on the crash bar and I used the 3 piece clamp for 1" bars. They mounted just fine and they are able to be adjusted up and down and sideways. I have them turned out to the sides to light up the ditch so I can see Bambi better.
http://i36.photobucket.com/albums/e4...1/IMG_0226.jpg
Joker
