Too tight under seat
Old Aug 31, 2008 | 06:26 AM
Bruno's Avatar
Bruno
Default Too tight under seat
I have an 08 Ultra and just installed the VH Fuelpack as well as the HD Rear LED wing and accessory rear lights. Only other hook up to the battery is a battery tender. Now I cannot get the battery cover to mount back on the top of the battery and although I got it close, the seat will not go on. I tried trimming the tabs on the battery cover, but no good.
With all the bikes I have seen with accessories, someone has had to have had this situation. Bike is parked and now with the pipes and accessories on, I am dying to ride.
Thanks in advance,
Old Aug 31, 2008 | 07:02 AM
jcbpa's Avatar
jcbpa
It's tight, but I got several things under there. I'm not happy with the potential issues of abrasion etc, but not sure what else to do. The benefit of the SERT is no box, but all the lights, etc... Let me know what you find out please.
Old Aug 31, 2008 | 10:12 AM
Garemlin's Avatar
Garemlin
I have a run/turn/brake module and a Smart Equalizer, Fuel Pak, and fuse for my HID headlight. The Fuel Pak is not an issue because it mounts under the left side cover. Both light modules I have hanging down by the frame going under the right side cover and the fuse for the HID I tucked in front of the battery. Sometimes it takes a little creative routing to get everything to fit.
Old Aug 31, 2008 | 10:16 AM
DrPlastic's Avatar
DrPlastic
Ditto what monstermile said. As a matter of fact there is a lot of room under the right side cover. And nothing to block like fuses and such.
Old Aug 31, 2008 | 03:47 PM
Bruno's Avatar
Bruno
Thanks guys. I think I should have been more specific. My problem is that where the fuelpack plugs into the ECU. If I keep it mounted onto the plate where the ECU mounts, I can't even shoe horn it in. I have the fuelpack "brain" if you will mounted on the left side on the fuse box as per instructions. I was able to move some things, but still can't seem to get that sucker to sit flat enough to mount the seat.
I am thinking of removing some of the zip ties and trimming the ECU plastic holder some. Thinking first, cutting second. I will take any tips.
TIA
Old Aug 31, 2008 | 04:08 PM
Garemlin's Avatar
Garemlin
That is really weird. There should be plenty of room under there. Here is what it looks like under mine.
nosparkoflife
Mar 25, 2014 11:10 PM
skully1200
Nov 25, 2011 02:11 PM
Jinxie
Nov 23, 2009 06:24 PM
mangiacavallo
Aug 19, 2009 06:16 PM
williamb_17
Jun 26, 2008 08:37 AM
