fuel pump swap
Old Sep 1, 2008 | 10:27 AM
shuvelhead's Avatar
shuvelhead
Default fuel pump swap
I have a 1998 FLHRCI fuel injected Road King. It is technically a basket case and I have NO tank. I would like to use sheet metal from a newer (2004 FLHRCI) bike. My question is relating to the fuel injection system and the fuel pump. I understand that I will need the later pump because the 1998 pump will not mount in the newer tank so if I get an '04 fuel pump mounted in the '04 tank will it work? Is everything else, pressure, fittings, lines, hoses etc. the same? Will this work, or can I make it work?
Hair53
Jan 1, 2021 02:21 PM
labelkil1s
Dec 10, 2011 06:12 PM
Bobbed Out
Feb 3, 2010 08:07 PM
shuvelhead
Exhaust System Topics
Sep 1, 2008 05:02 PM
