Windshield scratch question
Old Sep 2, 2008 | 07:23 AM
tah796's Avatar
tah796
Default Windshield scratch question
I've always cleaned my windshield with wax, which has always worked well. The other day, however, I must have used a cloth that was was too rough. I now have scuff marks all over the place and it looks like all the wax didn't come off (cloudy) when the sun hits it at the right angle. Is there anything the will bring back the nice clear finish????
Old Sep 2, 2008 | 07:45 AM
Chula's Avatar
Chula
I would also like to know as I to have scratches that I can not remove.
Old Sep 2, 2008 | 07:47 AM
dog155's Avatar
dog155
Had the same problem.The problem is the shields are coated,once you start trying to polish out a scratch you wear through te coating and it is all down hill after that.You might try a Google search or a glass dealer to find a way to clear things up.I had to replace mine.Good Luck
Old Sep 2, 2008 | 07:48 AM
spence222's Avatar
spence222
I use Meguiars Plastx.....works wonders on my windshield.
Old Sep 2, 2008 | 07:49 AM
spence222's Avatar
spence222
....it removes fine scratches, removes oxidation and haze and cloudiness.
Old Sep 2, 2008 | 07:50 AM
hawg08's Avatar
hawg08
Plexus Plastic Cleaner and Polish. I got mine at the dealer.
Old Sep 2, 2008 | 07:52 AM
C Clamp's Avatar
C Clamp
Meguiar's Plastix Plastic Cleaner & Polish here. Works good, actually buffed out some scratches using a small buffing wheel and the battery drill on slow speed also.
http://www.properautocare.com/meplplclpo2.html for a visual. I think I picked mine up at wally world.
Old Sep 2, 2008 | 08:36 AM
Theakerr's Avatar
Theakerr
Go down to your local small airport and pick up a bottle of LP Aero Plastics Inc Acrylic Polish and sealant for aircraft windshields or some equivalent. Works a treat. Acts as a filler. Will also work on visors and since it is clear i have used it on scratches in paint surfaces. No affiliation with the company
Old Sep 2, 2008 | 08:45 AM
Sketz's Avatar
Sketz
The best I have found and have used for years is Novus 1,2, & 3. Novus 1 is a cleaner, shine and protect version, Novus 2 removes small scratches, and Novus 3 is more of a heavy duty scratch remover. Most bike shops carry it, including Harley stores, in my area anyway.
http://www.novuspolish.com/
Old Sep 2, 2008 | 09:08 AM
tda69's Avatar
tda69
+1 on the Plexus. They have a 3 step process from mild to severe scratches.
