front mastercylinder cap and gasket
Old Sep 6, 2008 | 08:41 PM
FOCI's Avatar
FOCI
Smile front mastercylinder cap and gasket
i was wondering if anyone had the same problem that i did well i have 2006 streetglide with a little over 10 thousand miles and i have to replace the front master cylinder cap and gasket anyone ever heard of this problem before any information will help thanks for your input .
Old Sep 6, 2008 | 08:45 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Yep, it is/was a warranty item. I had an issue with my '07 and warranty covered it. One of those "silent" issues. They changed the material in the gasket to prohibit brake fluid oozing out and corroding the cap in the new gasket they replace the old one with.
Not sure if I made my point clear, but to summarize the newer gaskets used are a new material from the older ones and these newer ones don't allow the oozing between the cap and gasket.
Kinda one of those things that if you don't mention it, HD won't either.
Old Sep 7, 2008 | 12:50 PM
FOCI's Avatar
FOCI
well mine is out of warranty so i have to do it myself
Old Sep 7, 2008 | 01:09 PM
07flicks's Avatar
07flicks
I have the same problem on my 2007 with 10,500 miles and I will have it looked at monday when my bike goes in for the broken fairing mount
Old Sep 7, 2008 | 03:06 PM
roxnatwist's Avatar
roxnatwist
I had the problem on my front AND back master cylinder covers. Replaced both of them with the chrome covers and solved the problem...plus, it looks nicer.
Old Sep 8, 2008 | 10:22 AM
HDSAE60's Avatar
HDSAE60
06 egc same prob here!
Old Sep 8, 2008 | 10:26 AM
OhioSkully's Avatar
OhioSkully
2007 Superglide same problem took it in and they replaced it under warranty.
Old Sep 8, 2008 | 10:34 AM
petemac's Avatar
petemac
I have an '06 RKC and never heard about this problem. Hmmmm......
Old Sep 8, 2008 | 03:00 PM
roxnatwist's Avatar
roxnatwist
Hey petemac, take a look around the edges of your master cylinder where the cap and gasket meet the body. If your's is leaking, it will be raggedy and rough looking where the corrosion is starting. Maybe you are one of the lucky ones and won't have to mess with it.
Old Sep 8, 2008 | 03:15 PM
rapz's Avatar
rapz
I have that on my '08. I thought it was from someone spilling brake fluid, but is this also a warranty issue on the '08s?
