Rock chip
Old Sep 13, 2008 | 10:48 AM
spizzyman's Avatar
spizzyman
Default Rock chip
I have a dime size rock chip on my bat wing. My touch up paint skills leave a lot to be desired and it shows. What would a fair price be to have it repaired? I would leave it be and just might, but it is one of those things that sticks in my brain and my eye goes right to it when I look at the front of the bike.
Is there a DIY fix that I just don't know about or am I forced to take it to a shop?
spiz
Old Sep 13, 2008 | 10:54 AM
Bertk's Avatar
Bertk
Sure beats getting hit in face with it. Get one of those bullet hole stickers and place it over it.
Old Sep 13, 2008 | 11:01 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Trick to using touch up paint is to buy a good very fine tipped paint brush and just dab the center of the chip. The paint will spread out on its own to fill in the chip. Let that dry and continue to do that until the chip is filled in to your satisfaction. Let dry between dabs. If your brave enough, build the chip up higher then the paint around it and use some 2000 fine wet sanding paper to blend it in. Just do a little wet sanding at a time so you don't cut through the clear coat. A little polish to get rid of the hazing from the wet sanding, some wax and if you did the job right, it will be hard to see the chip area. Yeah I know, easier said then done!!
Old Sep 13, 2008 | 11:11 AM
fastbagger's Avatar
fastbagger
Make an insurance claim. That would be covered under your comp coverage.
Old Sep 13, 2008 | 11:59 AM
Ultra 08's Avatar
Ultra 08
+1. This works great, but don't get in a hurry. If done right, you will be the only one who notices it.
Old Sep 14, 2008 | 12:38 AM
spizzyman's Avatar
spizzyman
OK, I decided to do it myself and see what happens. I am building it up and purchased some 2000 grit paper for the wet sanding. I will try not to get too much of the surrounding area with the sand paper but know it will happen at least a little. Should I be using 2500 or 3000 grit to smooth at the end before waxing? If it goes well I will post some pics. If not, a local shop will make a few bucks LOL.
spiz
Old Sep 14, 2008 | 01:02 AM
philgrocks's Avatar
philgrocks
After you sand with 2000 grit paper (make sure you wet sand it), you will need to us a rubbing compound to get rid of those scratches.
These guys make kits with everything you will need.
http://www.langka.com/chip-scratch-repair-c-21.html
Not associated with their products, but have used them with success.
Old Sep 14, 2008 | 06:49 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Stick with some clear coat polish or a product that removes fine scratches first. If your not used to working with rubbing compound, you may do more damage then good.
Old Sep 14, 2008 | 07:01 AM
mtairy biker's Avatar
mtairy biker
Its a 03 bike what do you have to loose try it your self and you can have it painted by a pro if you screw up not like it is to earley for a paint job anyway
n8dc's Avatar
n8dc
I would use in this order 1500 or 2000 grit then 2500 and 3000 if you can find it . Then a medium duty rubbing compound followed by a polish. I like mequires stuff my self. Im in the process of building mine up with paint right now to get it ready for wet sanding but mine is a tri coat and the touch up is 2 part.*&^% Oh ya when wet sanding put a little liquid dish soap in the water and it will sand a little easier cause the paper wont stick or you can wet sand with meguires detal spray. You can also run down to the local auto parts store and they do sell clear in small touch up bottles that you could brush over the top before sandind and rubbing also.
Dave
