Burn MP3 What am I doing wrong!!!!!
Old Sep 15, 2008 | 11:43 AM
BlackBagger's Avatar
BlackBagger
Default Burn MP3 What am I doing wrong!!!!!
OK, so I take about 165 songs, all in order by Artist. I burn them to a CD as Data. When I put it in the radio it plays without a problem, except, the order is all different!
Anyone have this problem? Know a solution? Use a program that works?
Thanks,
Mike
Old Sep 15, 2008 | 11:54 AM
gman's Avatar
gman
i think they play, alphabetically, by the name of the song?
Old Sep 15, 2008 | 12:02 PM
asatguy's Avatar
asatguy
Using Nero or Roxio software should allow you to create a CD project (containing the 165 songs) and see in what order they appear prior to actually burning on to the CD. You should also be able to changed the sorting/order of the songs, within the CD project, before actually burning the CD. Give that a try.
Old Sep 15, 2008 | 12:06 PM
Windup08's Avatar
Windup08
If you want to make sure they play in a specific order you might want to add a number to beginning of each name, otherwise Windows will arrange them in a folder in alpha order and you burning software will do the same thing.
Old Sep 15, 2008 | 12:28 PM
Desoto's Avatar
Desoto
Or you can just use iTunes like I do to burn a mp3 Cd. There's even a random option so you don't have to listen to your song un alphabetical order.
Old Sep 15, 2008 | 12:37 PM
crp5's Avatar
crp5
I've used Itunes in the past, but only been able to get 15-20 songs per CD. Is there some special trick to get 165 songs on a single CD. That would be awesome.
Old Sep 15, 2008 | 12:41 PM
tinshield's Avatar
tinshield
Default Mpe
When you load the songs into your burner program they normally will change the sequence according to either the date or the length of the file.
Old Sep 15, 2008 | 12:42 PM
Desoto's Avatar
Desoto
You can burn a mp3 CD withiTunes, in the preferences, go in the advance tab and select burn mp3 CD instead of music CD and you'll be able to burn 150+ songs on a disc. I have 147 song on a CD burned with iTunes.
Old Sep 15, 2008 | 03:30 PM
hawg08's Avatar
hawg08
Maybe you have your player set to the RANDOM mode.
Old Sep 15, 2008 | 03:38 PM
HarleyWood's Avatar
HarleyWood
I use Windows Media Player without any issues. They burn and play in the exact order that I add them to my playlist.
My current MP3 CD has 198 songs on it.
harleybill2008
Jul 21, 2012 10:49 AM
HDJIM1158
May 23, 2011 07:51 AM
Cowracer
Oct 17, 2008 10:33 PM
mwriggs
Mar 3, 2008 08:56 PM
bigbean78
Jul 23, 2007 12:57 AM
