'04 Ultra - - Cruise Control problems
Old Mar 27, 2006 | 05:21 PM
deke463's Avatar
deke463
Stage IV
Default '04 Ultra - - Cruise Control problems
I have an '04 Ultra Classic and the cruise control (CC) is experiencing some problems: While running above minimum speed with the CC console switch in the "ON" position, when I attempt to activate the CC via the handle bar toggle button, the CC will not engage. The light will be illiuminated RED but CC will not engage. The only pattern is, after I toggle the console switch two times or so, the CC can then be activated via the handlebar switch.
If I disengage the CC via the brakes, or throttle, while the bike continues to run, the CC will not re-engage nor will it resume to set speed.
If the ignition switch is off and the CC selector switch is in the "ON" position, and then the bike is started, the indicator light in the tachometer will illuminate GREEN! Even at zero speed. If I briefly toggle the handlebar switch, then the light will return to RED, but when I achieve speed above minimum, the CC will not engage.
Does anyone have any experience with this problem?
Old Mar 28, 2006 | 12:11 AM
MACK's Avatar
MACK
Default RE: '04 Ultra - - Cruise Control problems
YOUR MODULE IS ABOUT TO QUIT. $149.00. BEFORE YOU SPEND THE MONEY THERE IS ONE THING TO CHECK. ON THE RIGHT SIDE AT THE NECK YOU WILL SEE THE WIRING HARNESS. ONE OF THE CABLES HAS A BELL SHAPED GASKET AROUND IT JIGGLE IT SLIGHTLY AND SORT OF MOVE IT. IT SOMETIMES BINDS. IF THIS DOESNT WORK YOU HAVE A BAD SWITCH MODULE.BEEN THERE, DONE DAT.
Old Mar 28, 2006 | 08:32 PM
deke463's Avatar
deke463
Stage IV
Dear Mack,
Thank you very much.
DEKE463
MURPHCC1
Electrical/Lighting/Alarm
11
Oct 15, 2019 01:36 PM
Bubba Zanetti
Oct 2, 2017 10:30 AM
Divebuck
Jan 8, 2012 11:48 AM
bambamblazer
Jul 15, 2011 09:59 PM
2007rkjb
Apr 6, 2011 10:05 PM
