Do you have ABS? If you do, you might not be able to use these wheels as the hub on the left side has a groove in it. whether this is important or not I do not know just yet. If you do not have ABS than just buy R&R your 25mm bearings or just buy new 25mm bearings and wheel bearing spacers. This will work.
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
no abs on iether..i have taken the bearings out of both but not only is the inside diameter different they are different widths as well..just thought it would be iesier to chg axles?
He (fathertime) called me but I dropped the call. I was on my cell phone away from my desk. I could not call Canada on my cell. I dropped him a e-Mail and also called the number on caller ID from my desk on my cell. The number and phone he used was not his own and I made every effort to get back with him including this posting, phone call, e-Mail and private messaging through this site. Sorry to mislead you guys.
Lets assume you find 1" axles, how you gonna make them work with the ids bearing in the ids bucket? Im fighting the same mission as you, the best way is to buy the right kit from harley and change bearings and spacers. search on touring section and look for question on wheels/vs bearing kits, now on page 5 or 6 now. Read the response from DAWG and follow his more direction, its a great document and gives all the answers.
ok thanks .. on the front i ended up changing the bearings and spacers from the 08 wheel into the 07 laced and it worked out fine.. havn't done the rear as of yet..and didn't realize the ids would be a problem considering lots have retrofitted ids onto the 07's??
thanks for your help i wasn't trying to snub you in any way ..i just thought you were really busy and went ahead and changed the bearings and it worked out o.k..i appreciate any help..and i don't understand why the call display gave you a different number , iwas calling from my desk at work (work related) lol..if i run into problems on the rear i will call you o.k?
