ABS Bearings Touring
Old Feb 21, 2019 | 12:06 PM
Road Gliderman's Avatar
Road Gliderman
Default ABS Bearings Touring
I have ABS and I am going to swap wheels on my Road Glide the bike the wheels are coming off of is not ABS so I will have to change the bearings. My question is do you only have to put an ABS bearing in the side the sensor is or do you have to put ABS bearings in both sides of the wheel. Sorry if this has been posted, looked quickly couldn't find anything.
Old Feb 21, 2019 | 02:55 PM
Lude-a-tick's Avatar
Lude-a-tick
ABS bearing is on the side the sensor is on...left for front and right for rear.
Old Feb 21, 2019 | 03:56 PM
lightweight bob's Avatar
lightweight bob
I may be wrong but as I recall the ABS bearing is wider than the standard bearing - are you sure the wheels will
interchange?
Old Feb 27, 2019 | 08:26 PM
penmaker's Avatar
penmaker
interchange?
You're right, the ABS bearing is wider than the standard bearing. I just changed bearings on my '14 Limited. OP...look up the specs on the bearings and then measure the wheels you're putting on to make sure the ABS bearing will fit.
Old Feb 27, 2019 | 09:30 PM
multihdrdr's Avatar
multihdrdr
Don't make this into a "Problem"
Same wheels, ABS or Not ... follow Post #2
dgoodbmw
Jul 26, 2017 10:10 AM
jwk784
Mar 21, 2013 06:18 PM
dabo0652
Jan 30, 2013 06:25 PM
dabo0652
Jan 23, 2013 11:50 PM
BIGVTWIN
Dec 22, 2012 04:28 PM
