Rk engine humming
Old Sep 23, 2008 | 12:17 AM
CRANUPAS's Avatar
CRANUPAS
6th Gear
Question Rk engine humming
I own a 1995 Road King with 61,000 miles ...
On coming back to town after a 300 miles trip I started to hear a kind of high intensity noise from the engine...I took to the mechanic and he found a worn out camshaft bearing which caused the camshaft tip to come out of true. He replaced both the needle cam bearing and installed and EVO 3 camshaft, since a standard one was not available...
I am now having an -all the time present- engine humming....which annoys me a lot. ..
The mechanic argues that it comes from the old oil pump pinion and the new camshaft in-gearing.
Beside of that, the engine goes fine and pulls like a rocket...
Will this abnormal noise cause a greater future damage to the engine?
Please enlight me...
thanks in advance
Cranupas
Old Sep 23, 2008 | 05:42 AM
newrench's Avatar
newrench
Did he press your old cam gear off and install it on the new cam? A bike with that many miles should stay with the matching pinion and cam gear. sounds like the gear lash is to tight caused by a bigger cam gear on the new camshaft.
Old Sep 24, 2008 | 10:01 AM
CRANUPAS's Avatar
CRANUPAS
6th Gear
Thanks foryour opinion, but my main concern is still the eventual damage that this humming (knowing its cause) could develop in the other engine components.
96 fatboy
Engine Mechanical Topics
30
Apr 11, 2016 07:23 AM
widegliderider
EVO
Oct 30, 2011 05:37 AM
paulhog
Aug 26, 2010 10:37 PM
t059736
Jun 17, 2010 11:56 PM
pjran
May 18, 2010 01:18 PM
