F&H Fuelpak Users?
Old Sep 25, 2008 | 11:45 AM
  #31
Rocket_Rider's Avatar
Rocket_Rider
Originally Posted by Bluesssman
Put one on my 07 Road Glide. Did not like the unit and really was disappointed in the lack of support. They were not willing to discuss what each of the settings. I replaced it with a Power Commander III which I bought from Jamie at Fuel Moto www.fuelmotousa.com. I really like how easy it is to use and make adjustments.
I did the same. I was very disappointed in the performance with the Fuel Pack. Called numerous times and emailed VH. No response. Bought a PClll Powercommander and will never go back. It's like two completely different bikes.
Old Sep 25, 2008 | 11:57 AM
  #32
ngoti8tor's Avatar
ngoti8tor
I'd like to know how everyone is getting their temperature measurements. Are you actually using some measuring device, or are you just assuming it's running cooler?
Thanks
Old Sep 25, 2008 | 12:19 PM
  #33
tano01's Avatar
tano01
Originally Posted by mile high king
2008. Again, it still feels very hot, but I have no before / after temperature measurements to let me know if the V&H changed anything. Others on the forum that understand the EFI better would more more appropriately comment, but I still think that even with the V&H fuel-pak you are still keeping it to the factory 14.7 to 1 fuel ratio (at least during closed loop operation) so while the Fuel Pak makes sure that the bike runs correct with the open air clearner and after-market pipe, correct is still defined as 14.7 to 1 and is therefore still lean. It is the 14.7 to 1 leanness that makes the heat, so if the FuelPak doesn't improve that then how could it make it cooler? BTW, I could be completely wrong on all this technical stuff, all I know is the bike still is hot..could be less hot that it was before but it is still hot.
I am technical illiterate...I kind of see where you are coming from. From what I can gather from the PCIII conversations I have read and the Fuelpak conversations - unless the air/fuel mixture becomes more rich, then there is a heat issue as the bikes run lean to begin with. That is probably a gross over simplification. I'm not looking to have a bike with no engine heat, just like to tune it down a notch so my nuts don't get roasted when I ride home from work.
Would anybody say it is true? If so, it appears that you cannot set that up on the Fuelpak?
Old Sep 25, 2008 | 01:07 PM
  #34
kwb377's Avatar
kwb377
Thanks
I'm using my "highly calibrated" inner right thigh as my gauge.
My previous '05 would almost literally cook my leg in stop/go traffic...the heat would get to the point that I thought my leg was sure to blister. My current RK doesn't get anywhere near that hot. If it's putting out the same amount of heat, it's doing a good job of hiding it from me...
Old Sep 25, 2008 | 01:09 PM
  #35
kwb377's Avatar
kwb377
Thumbs up
Originally Posted by tano01
What part of Birmingham are you in? My sister lives up there so I visit all of the time.
I live on Kimberly (north Jefferson County) and work in Homewood.
Lemme know if you're up this way riding...
Old Sep 25, 2008 | 03:11 PM
  #36
glens's Avatar
glens
If your EFI has the O2-sensor feedback loop, you'll not affect the heat output. If it doesn't, you'll be able to.
Old Sep 25, 2008 | 03:13 PM
  #37
tano01's Avatar
tano01
They are over in Trussville right now...they are about to hatch a new kid, so I may be up there. I'll drop you a PM if I do.
Old Sep 25, 2008 | 03:15 PM
  #38
tano01's Avatar
tano01
I got this from V&H about the air/fuel ratio:
"The Fuelpak changes the air to fuel ratio to 13.8 to 1 . This is considerably richer than stock which is 14.8 to 1."
Old Sep 25, 2008 | 04:15 PM
  #39
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Works for me, and tech gave me confiquration for 95" & cam. Haven't tried that yet.
Old Sep 25, 2008 | 04:19 PM
  #40
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
First off, I am not a mechanic. I don't pretend to be. In spring of 2006 I bought a 2006 Dyna Super Glide. After the 1000 mile check I bought V&H straight shot slip ons a K&N AC and the V&H Fuel Pak and installed them myself. The bike ran strong with no decel popping. I sold it to a riding buddy who has been riding it for 2 years now with no problem. I'm looking at buying a 2009 SG or EG Classic. I plan on installing V&H Big Ovals and a K&N AC and Fuel Pak again.
