Installing Rocker box bolt covers
Old Sep 26, 2008 | 09:37 AM
sortasuave's Avatar
sortasuave
Default Installing Rocker box bolt covers
I hate asking what seems like such a dumb question but sometime you just gotta.
I purchased the following Rocker Box bolt covers to dress up my 07 Street Glide:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
The problem is, I can't figure out how to install them. It appears that hey should just snap over the top of the bolts. But try as I may, I can't get them to install. Is there some trick to getting these installed? I can successfully push them over a bolt of the same size elsewhere but I just can't get them over the bolts on the rocker box....
Old Sep 26, 2008 | 09:43 AM
rocknrod's Avatar
rocknrod
It says evo models. 1340CC
Think you need Twin Cam models http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Sep 26, 2008 | 09:44 AM
gmc's Avatar
gmc
Yeah they do go on hard. I think I used the end of a rubber hammer and then tapped on it. I put a little clear silicon inside them just in case.
Old Sep 26, 2008 | 10:26 AM
sortasuave's Avatar
sortasuave
Sorry about that. I didn't pay any attention to which one I linked to. I'll double check, but I'm pretty sure I've got the ones for the V-twin. The parts counter guy was the one that handed them to me and he knew what my bike was. (or so I'd like to think he did from our conversation)
Either way, I'll double check the part number.
Old Sep 26, 2008 | 10:39 AM
sortasuave's Avatar
sortasuave
I'll give that a try... Just didn't want to have to remove the tank and the seat to do this "simple" job since so many of the covers are in tight quarter under the tank....
Old Sep 26, 2008 | 10:50 AM
gmc's Avatar
gmc
What I meant was to put something on top of them that will fit horizontal and then tap out past the tank to get them on. You can use a paint stiring stick, etc. that wont scratch them. You don't have to take the tank off.
Old Sep 26, 2008 | 11:03 AM
timvan's Avatar
timvan
they go on tight...also helps to have the tabs lined up correctly with the bolt
Old Jul 8, 2017 | 03:31 PM
SgtThump's Avatar
SgtThump
I know this is an old thread, but i was searching for how to install these things myself. After fighting with them, i did as you said and used a small pry bar and rubber mallet. The last 6 went on faster than the first 2 with my fingers!
Great tip, thanks.
NewfieRocker
Apr 21, 2010 11:57 AM
bobby5
Mar 28, 2010 08:52 PM
Mtdew
Sep 4, 2009 02:18 PM
ucommbxny
Feb 16, 2009 09:42 PM
ronn39
Dec 22, 2005 02:23 AM
