stage one download
Old Sep 28, 2008 | 11:56 AM
gary_montague's Avatar
gary_montague
Question stage one download
Has anyone ever tried using a map for say the ES stage 1 A/C + SEtouring pipes for a bike that just has the Air cleaner changed to SE? I like my pipes the way they are, especially for $400. But I keep hearing a common complaint that the bike is running lean after download. I was wondering if the download for A/C and pipes both would be a bit richer than the download for just the A/C.
Old Sep 28, 2008 | 12:21 PM
Emporers New Clothes's Avatar
without pipes your bike doesn't have a demand for more air or fuel so I would say dont do the download unless its to change the rev limiter. the way the map works is it tells the fuel injectors to either send more or less fuel to the chambers for ignition so if the need for more isnt there ie... pipes then why send it. and putting a/c on a bike that isnt asking for it ie..one without pipes doesnt really make sense..
Just my .02
Last edited by Emporers New Clothes; Sep 28, 2008 at 12:23 PM. Reason: missspelled
Old Sep 28, 2008 | 12:58 PM
blueflht's Avatar
blueflht
emperor you have it backwards. by installing the s/e a/c you add more air to the mixture causing a lean and a very hot running engine. adding the download it richens the mixture to compesate. pipes with no a/c change are fine without a download. if this is all you want from your motor a stage 1 download is fine. did it to mine with no issues at all
cost 150$ for the download and 1/2 hr labor to install
Old Sep 30, 2008 | 11:30 AM
gary_montague
Thanks for the help I have about 6K on my roadglide and have noticed the pipes getting quite a bit louder just from use. I am guessing the packing is getting worn a bit
Jessie3306
Exhaust System Topics
Apr 4, 2015 02:02 AM
Whir
May 3, 2011 02:26 AM
firedyna
Feb 28, 2011 07:28 PM
nigelgeast
Sep 22, 2008 09:26 PM
drrandall1
Mar 25, 2007 02:40 PM
