Road King left Accessory switch
Old Mar 29, 2006 | 10:59 PM
dapster's Avatar
dapster
Default RE: Road King left Accessory switch
For any of those wanting to use the accessory connector without cutting/splicing the wiring harness, I have inlcuded one of my previous posts below.
ORIGINAL: dapster
I had the same dilema when I hooked up the Road Tech on my '05 RKC, what I did is hook up the orange/white wire to the left toggle switch as it is unused. This gives me the option to turn the radio power off/on even if the ignition switch was in the accessory position. However, after I did that I discovered that Harley has a switched circuit adapter harness that will plug in to the accessory switch harness under the seat. You can then splice into that instead of hacking into your factory harness. The part number is 70264-94A and runs $14.95. There is no picture on the HD website but if you have the 2006 accesories and parts catalog it is on page 494, Item E.
Hope this helps
Old Apr 1, 2006 | 01:34 AM
05RKC's Avatar
05RKC
check this out
http://www.zx6r.com/250/garagedoor/index.html
Old Apr 1, 2006 | 09:46 AM
mrbearski's Avatar
mrbearski
ORIGINAL: 05RKC
check this out
He had way too much time on his hands. But WAY cool!
Old Apr 1, 2006 | 10:39 AM
liam51's Avatar
liam51
Nitro Injector arming switch
Old Apr 1, 2006 | 12:17 PM
Whiskers's Avatar
Whiskers
My wife has her vibrator hooked up to it. Runs the battery down!! (J/K)
WorldPat
Apr 20, 2017 09:15 AM
driv3rx
Feb 9, 2016 02:52 AM
BD INC.
Sep 29, 2013 03:59 PM
charlie496
Feb 11, 2010 06:50 AM
Retired_Ted
Nov 17, 2005 12:22 AM
