Identifying ABS model
Old Sep 30, 2008 | 09:00 PM
global force's Avatar
global force
Default Identifying ABS model
I do not have access to a parts/service manual right now so how do I visibly tell if a bike is an ABS model or not? Looking at an 07 FLHP.
Old Sep 30, 2008 | 09:02 PM
Bradley Jones's Avatar
Bradley Jones
I think 07's have the abs unit in the saddle bag but that might be 06 and older models. I know on my 08 you can not tell (by looking)
Old Sep 30, 2008 | 09:05 PM
Ca.Fatlad's Avatar
Ca.Fatlad
On the 09's I believe that the inside spacer on the front wheel is black in colour, not sure If same for all years
Old Sep 30, 2008 | 09:07 PM
HDV-GLIDE's Avatar
HDV-GLIDE
There is an extra wire attached to the left (if your sitting on the bike) front brake line. Or you can look real close at the calibers and there is a small black tag with the letters ABS on it.
Old Sep 30, 2008 | 09:08 PM
bluffalobob's Avatar
bluffalobob
Look at the frame where the tubes meet at the front of the bike, right where the VIN is stampped on the right side. On an ABS bike there will be two cables. On a non ABS, it will be a single bundle of wires.
Deepsouth251's Avatar
Deepsouth251
I believe when you turn the switch on the ABS light will come on.
Old Sep 30, 2008 | 09:10 PM
DrPlastic's Avatar
DrPlastic
Check where the front brake lines join and branch at the lower triple tree. ABS models will have the brake lines going from the front master cylinder down the neck under the tank instead of a direct connection to the front master cylinder.
Old Sep 30, 2008 | 09:11 PM
FLHXn's Avatar
FLHXn
On the right front of the frame near the fairing wiring harness, you can see two black brake lines. These are the brake lines that leave the front master cylinder on the bars and head back to the ABS unit (under the right cover). The other is the brake line on it's way back to the front wheel. This is the easiest way to tell.
WildHair's Avatar
WildHair
On my 08 there is a black ABS sensor between the fork and the brake rotor. It's on the left side and clearly visible.
Old Sep 30, 2008 | 09:40 PM
Trock's Avatar
Trock
Yes, Right side will have a spacer the left will have a black sensor. If it's non ABS it will have a spacer on both sides
