GPS power cord ???????
Old Oct 5, 2008 | 08:54 AM
Mike07FLHTC's Avatar
Mike07FLHTC
Default GPS power cord ???????
I know allot of you hard wire your gps.Well I had plans on cutting off the cig lighter plug from the power cord.Before I did it I wanted to make sure the power output was 12v's.Well input is 12 but output is only 5volts.Any of you guys know how to get around this?I want to be able to unplug it and take the gps off the bike I only use it for trips and I didn't want to use the cig. lighter as it hits the tank at full left turn.Thanks.
Mike
Old Oct 5, 2008 | 08:58 AM
dawg's Avatar
dawg
Mine is hardwired, but I have a two pole flat wired in line so I can take it off. Pic below
Old Oct 5, 2008 | 11:04 AM
Mike07FLHTC
Dawg,
Did yours come like that or did you cut the plug off and wire it yourself? Thanks
Old Oct 5, 2008 | 11:44 AM
MeanMorningJoe's Avatar
MeanMorningJoe
My Magellan road mate needed a step down to 6 volts. I found someone on line that makes the harness with a heat resistant step down unit. Ran under tank and up under inner faring and then up the bars to the ram mount. If you have a 5 volt system, you can not simply cut of the charger head.
Wecroft's Avatar
Wecroft
You didn't say what brand / model of GPS, but if the output of the Cig adapter is only 5 volts then it is also a transformer/ voltagte regulator and you can't get around using it.
Old Oct 5, 2008 | 12:10 PM
Trock's Avatar
Trock
Try White Horse Gear. They have all kinds of wiring stuff that might help you. Just do a search on there site.
Old Oct 5, 2008 | 01:10 PM
rocknrod's Avatar
rocknrod
http://www.powerletproducts.com/products.php?mid=1
Old Oct 5, 2008 | 01:22 PM
dawg's Avatar
dawg
Originally Posted by Mike07FLHTC
Dawg,
Mine did not come like that. I cut the wires and put in the two pole flat connector as shown. I made sure that the positive lead was the protected one on the flat connector and not the exposed pole. I hooked it into the unused connector that is behind the headlight (used for HDI models)
Old Oct 5, 2008 | 10:30 PM
GT_RoadGlide's Avatar
GT_RoadGlide
If you happen to have a Quest model RAM has a power adapter for it
HD Mojo
Mar 17, 2016 07:47 PM
sanlyn
Jul 27, 2011 11:37 PM
TBinTX
Jun 11, 2011 09:43 AM
Brightonrider
Sep 6, 2010 09:03 PM
capt42a
Mar 30, 2007 07:13 AM
