FLHX Pullbacks
Old Oct 9, 2008 | 09:31 PM
jackinthebox's Avatar
jackinthebox
Not trying to hijack the thread, but are these bars easier to install than apes. Your labors figures are great. Ive been to two indies and the dealer and they all quoted me the same labor of 7 hr to install new bars. Didnt add up to 1800 but still a lot more than bar + 300.00
Old Oct 9, 2008 | 10:16 PM
Oldman Harley's Avatar
Oldman Harley
My HD dealer told me about 7-8 hrs labor for the install. I said screw that and did it myself it took me 11hrs. The handlebar part was easy it was the removal of the exhaust system for the longer clutch cable that was a bitch. I installed the Khromewerks #300515 +2 sweepers and the clutch cable was the only thing needing to be lengthend.
Tim
Old Oct 9, 2008 | 10:29 PM
Bertk's Avatar
Bertk
Installing different size bars themselves doesn't make that much difference. Changing cables, brake lines, and running internal wiring can add up quick. The clutch cable can be a pain because the clutch release cover has to come off. That means moving or removing the right side exhaust. With stock exhaust that means the hole thing. I have true duals, so all I had to do is loosen the right side and move it out of the way. The internal wiring isn't hard, just time consuming. So it depends what you have and what you want done. IMO, $1800 is way to much to pay.
Old Oct 9, 2008 | 10:37 PM
Bertk's Avatar
Bertk
Tim
Yes, that clutch cable can be a pain. True duals makes it much easier.
Old Oct 10, 2008 | 11:09 AM
06flstf's Avatar
06flstf
I had an Indy install bars from a same year Heritage on my Fatboy that had more of a rise on them. No cable swap - everything fit. Bars are closer to the seat and no more clamshell. I think it was around $50 bucks for the swap. Dealer wanted around $300 and was insisting that new cables be used.
Old Oct 10, 2008 | 09:24 PM
Bertk's Avatar
Bertk
My first touring bike was a 1999 RK and those bars where uncomfortable. My Indy had a set of Heritage bar sitting around and sold them to me for around $35. I installed them myself without having to change any cables. Those where the days.
Old Oct 10, 2008 | 09:53 PM
lp's Avatar
lp
Do yourself a favor. Before you install the HD pullbacks take them in your hands and check if they are going to be too narrow for her/you. Those bars are very narrow and make your wrists bend outward in a not so comfortable angle. Some like the bars...many don't and end up buying wild1 575 bars or the kromewerks 2+ sweepers later...
lp
Old Oct 11, 2008 | 11:07 AM
kbear's Avatar
kbear
Price was $989 Plus wiring and labor if it was 10 - 11 hours of install time maybe their time at $100/hr at maybe 9.5 hours for professional install. I'm not even going for a second opinion just going elsewhere that is a bit nuts. I could send it to Kirk and Kuryakan for less than that and have it installed. 500 - 600 dollars for install and 450 each way for shipping. Still shaking my head on that one. Mirrors being moved are extra...
Old Oct 11, 2008 | 11:31 AM
StreetGlideMedic's Avatar
StreetGlideMedic
I just went to My local dealer and checked on the same...we're talking less than half of what you're quoted...and that's form the most expensive guy in the tri-county area. Good Luck Brother! Mike
Old Oct 11, 2008 | 12:17 PM
Bertk's Avatar
Bertk
lp
+1 on the wrist angle.
