FLHX Pullbacks
Old Oct 11, 2008 | 12:31 PM
Bertk's Avatar
Bertk
Originally Posted by kbear
Price was $989 Plus wiring and labor if it was 10 - 11 hours of install time maybe their time at $100/hr at maybe 9.5 hours for professional install. I'm not even going for a second opinion just going elsewhere that is a bit nuts. I could send it to Kirk and Kuryakan for less than that and have it installed. 500 - 600 dollars for install and 450 each way for shipping. Still shaking my head on that one. Mirrors being moved are extra...
With some wrenching ability, a few tools, a service manual and patients, you can do it yourself and save $$$.
GasCan's Avatar
GasCan
A buddy of mine is an HD Wrench and I know their shop charges a flat rate of 6 hours to change bars on a bagger. This includes changing out the clutch cable. If the bars also require changing brake cables then that labour factor increases, as do the costs for new cables. Throttle by wire and routing through the bars takes some time, as does extending the wiring for longer bars where splicing and terminations are required to extend the internal wiring. Some bars are harder to do than others where they have to drill the bars to get the wiring in and out so account for that as well.
Myself, I went with 575 Wild 1's which are thicker bars and have larger openings to route the wiring. I also changed all my cables out for diamond backs, but did it while the entire fairing was apart so things were easier. I'd still say 1800.00 sounds really fat so check some of the reputable independants around Vancouver and you'll likely find some better rates. In either case, the labour can be extensive, and it will double if she's looking for heated grips on an 08 or 09.
Wild 1's are about 175.00 for the bars, cables are over and above that. Here is a picture of the finished bars with braided cables.
Old Oct 11, 2008 | 12:42 PM
GasCan's Avatar
GasCan
Oh yea, the larger bars make it a bit difficult to see via the fairing mirrors, but they still work. I wasn't about to add a fugly set of bar mirrors to mine so i left them as they are. Just gotta look over my knuckles to see, but it's manageable. You can always tilt the bars back a bit and this allows you to see better, but it's all dependant on the riders preference on where the bars are going to be situated. If you end up changing them out, make sure she sits on the bike while the bars are being mouned so she can let them know exactly where she wants them postioned.
Wam
Mar 21, 2018 03:33 AM
hog95023
Aug 14, 2011 10:30 AM
2smoooth
Jan 10, 2010 11:36 AM
SA315B
Feb 15, 2009 02:39 PM
Hoffy
Aug 10, 2008 06:31 PM
