Clean up help needed
Old Oct 13, 2008 | 08:06 AM
Ohio HD Guy's Avatar
Ohio HD Guy
Default Clean up help needed
I must of caught a plastic grocery bag on my muffler when I was on the highway and it seems to be baked on now. Any suggestions to get it off?
Old Oct 13, 2008 | 08:10 AM
dFREDb's Avatar
dFREDb
Try "Goof Off". You are still gonna need some elbow grease too! Let it cool off and try to soak it ie. wrap a small towel soaked in the cleaner around the pipe.
Old Oct 13, 2008 | 08:28 AM
spizzyman's Avatar
spizzyman
Any chrome cleaner/polish should work. Goof Off might be just fine but as stated above, you will need to work it.
spiz
Old Oct 13, 2008 | 08:30 AM
MyFirstHD's Avatar
MyFirstHD
Heat your pipes and use oven cleaner. Be careful to spray it on a rag so you don't get any on your bike.
Old Oct 13, 2008 | 08:48 AM
Potato_Potato's Avatar
Potato_Potato
Just took some off a friends bike with WD40 & 000 fine steel wool. I would try this before oven cleaner.
Old Oct 13, 2008 | 09:41 AM
kwb377's Avatar
kwb377
If all else fails, try a product called "Aircraft Stripper" paint remover.
I ran over a juice box that the kids left in the driveway, but didn't realize until the next day after it had tried onto my muffler (it took awhile to figure out what it was...looked just like brake fluid). I first tried mineral spirits and steel wool to no effect. Finally had to resort to the paint stripper...worked great.
Old Oct 13, 2008 | 09:48 AM
kwoozn's Avatar
kwoozn
Someone mentioned in another thread about using a penny.
Never tried it, not sure where it was posted.
Old Oct 13, 2008 | 10:03 PM
bigskyhd's Avatar
bigskyhd
Once again, I'll share the British trick for this. Grip a US penny between your thumb and pointer finger, now rub the plastic off your pipes. The copper is softer than the exhaust chrome, and it won't leave a mark. Test it on some of your "take off" parts first if you are afraid it might mark them. Easiest way to get it off. Then let us know how it works....
Old Oct 13, 2008 | 10:26 PM
will2002's Avatar
will2002
I KNOW the WD40 and 0000 steel wool works. Done it just last week!
Old Oct 13, 2008 | 10:30 PM
tima's Avatar
tima
Another thread was useing the "Easy Off" oven cleaner and swearing by it (not at it). Like Myfirsthd said, don't get it near the paint. Spray it on a rag and then wipe the pipe down.
kjkustoms
Jul 11, 2011 09:06 PM
Great Gazoo
Jun 23, 2010 02:33 AM
tonygret
Apr 26, 2010 02:50 PM
Madmurph
Detailing
Aug 17, 2009 11:06 PM
arachman
Exhaust System Topics
May 17, 2006 05:20 PM
