My Theory About The Fairing Braces
Old Oct 16, 2008 | 07:31 AM
harley-jones's Avatar
harley-jones
Here is some food for thought.
I had my outer fairing off for a wiring problem. When I put it back together I torqued all the fasteners to factory specs.
About 100 miles later I checked those same fasteners and they were all loose and needed to be re-torqued.
I am thinking that the brackets are breaking because the fasteners inside and outside the fairing are loosening up and causing vibrations to occur.
The front end (Batwing) is constantly buffeting in the wind, jarring and shaking with bumps, expanding with heat and contracting with cold and constantly moving around as we ride causing fasteners to loosen and vibrations to start.
My plan is to remove the outer fairing as routine maintenance and make sure everything on the inside and outside is tightened to factory specs.
That's my plan..........Only time will tell if I am correct.
Old Oct 16, 2008 | 07:36 AM
FastHoss's Avatar
FastHoss
Wonder if they made them better on the 09,my 05 has been just fine,don't see how they could break.
Old Oct 16, 2008 | 07:45 AM
HDDOC's Avatar
HDDOC
09s same same. Doc
Old Oct 16, 2008 | 12:13 PM
harley-jones
Does the left or right side break more often? Anybody know?
Old Oct 16, 2008 | 12:29 PM
atrox88's Avatar
atrox88
Originally Posted by StreetGlider56
My theory is it's cheap Chinese junk...
If we're going to get out of this mess, America needs to start manufacturing again. So what if it cost more, at least it's quality and you won't be buying two or three of them...
Just my .02c
+1 on that
Old Oct 16, 2008 | 12:33 PM
russl179's Avatar
russl179
Originally Posted by atrox88
+1 on that
Until we stop taxing the crud out of businesses, they will continue to move overseas.
Old Oct 16, 2008 | 01:05 PM
Ridewva's Avatar
Ridewva
I can't tell if this a repair for the Batwing brackets, or a repair for their compressor bracket? http://www.savior250psi.ca/QuickRepair_about.html
Old Oct 16, 2008 | 01:06 PM
Wassup8687's Avatar
Wassup8687
That was brought up on the Presidential debate last night by John Mcain. He's trying to stop companies from leaving the US.
Old Oct 16, 2008 | 01:51 PM
dgriffith's Avatar
dgriffith
RideWva, Those are a replacement for the top ends of the main fairing braces that break off. Good idea, but I wouldn't use pop rivets to fasten it on, I'd use bolts with nylock nuts. Mine broke early this spring. I took them off and welded them back together. Then I took a piece of .062 metal, 1 in wide and long enough to make a J shape to outline the outer curvature of the end that broke off. With that welded on, the whole end is reinforced. Done a similar thing to the small braces.
customsoftail200
Aug 23, 2021 12:18 PM
twp98
Oct 17, 2015 06:04 AM
lynn barr
General Topics/Tech Tips
Aug 7, 2010 09:56 AM
Jezcruzen
Mar 9, 2008 06:46 PM
monkish
May 19, 2007 07:44 PM
