Thats a nice build!! Did you have pinging with the 585's. I thought the 570's were for lower compression motors, thats why I went with the 585. I think your right.....I went with the wrong cam. Damn it anyway.
Just hold off purchasing cams.
Let me get you some feedback on these 570's.
A couple buddies are wanting to find out about the 570's, too.
They're running 585's.
I get to be the guinea pig.
The 570's I believe are for a lower compression, however..this is the cam Branch recommended with their setup.
Being the "manly man" I thought I should be, I wanted it all.
Guess I'll return to my chic roots, drop a cam size...and ride off into the sunset.
LOL
The difference in loss in power from 9:5 to 10.5 is not allot of power left on the table period. Maybe 5HP if you have fuel that will not pre-detonate. The problem with high compression and pump gas you end up tuning the performance out of it so it will not detonate by pulling timing, or running it way fatter which is not efficient. At the end of the day you are no better off with higher compression over 10:1 in most cases. Personally, I do not know why so many choose to run the envelope of detonation on pump gas. On compression it is a linear curve. To get a decent gain in power from 9:5 you would need to go 12:5 for a meaningful power gain. Also remember these are obviously air cooled engines that run hot. That makes this engine more sensitive to detonation.
That all said, more is not always better. In the case of running a bottom end cam with shorter duration the static compression is going to be higher then it would be with a midrange cam. Low RPM detonation will rear its ugly head sooner, then a cam with longer overlap event.
All said and done I am not slamming anyone. I just think there is a huge misunderstanding about compression, versus power made, versus potential detonation issues as being discussed here. 10:1 on today's pump gas, is the edge with aluminum heads.
Just one mans opinion, who has built lots of performace oriented engines.
Do you think I should install a thicker head gasket and lower the compression a bit? I agree I wouldnt notice a difference. I do believe my bike has been tuned to a lower performance to get away from the ping. Im picking up what your throwing down..
Yes I would give that a try. In the next breath, I will also say that while it fixes one problem, it screws up the squish a wee bit in the chamber, so you are again faced with a negligible loss in power. That said, ideally it should have been set up 10:1 on a zero deck. That not being a cheap option at this point, then yes I would increase the head gasket and drop the compression, Detonation if left unchecked will do one of two things or both. Hammer the rod bearings down to the copper, and in the worst scenario break a piston ring land. My highest recommendation is to solve this problem and quickly! >
I'll throw in that you might get out the laptop and take some timing out at various throttle positions below, and up to 3000 rpm on both cylinders.
Try the link below to see a basic 'don't get yourself in trouble' timing table for a PC III from the Headquarters website. There is one for a SERT, etc.
I wish I lived near you. I'd take that oil you're throwing out at 1200 miles. It's still good as new, especially synthetic. New enough for me to use anyway.
