Street glide
Old Oct 21, 2008 | 05:25 PM
Hogman07's Avatar
Hogman07
Default Street glide
Has anyone upgraded there motor from a 96 to a 103 or 110 , was there a big difference that was noticed from 96-103. Also were there problems to follow. Thinking of doing this durning the winter
Old Oct 21, 2008 | 05:39 PM
Phurion's Avatar
Phurion
I went with the straight SE Stage II 103" kit, no head work. Jugs, pistons, 255 cams.
No regrets what-so-ever. I only had to pay for the parts I listed above since I was having some other warranty work done that covered the cost of labor and the non-reusables (gaskets and such). My total out of pocket for the upgrade was just over $700, so I'm pretty damned happy with the $$ to power ratio on the deal.
The seat-O-meter is very pleased.
Some will recommend other brands (HQ's rate pretty highly here), but for what I was getting (and how)...the SE was the best option for me.
Old Oct 21, 2008 | 05:44 PM
dmgary's Avatar
dmgary
I went to a 103 flat top pistons, SERT, 255 cams and v/h big radius pipes you can look at my post( wow shes hot is the name) and see my numbers in my sig it has a walk around. If you do head work you can easly see over 100 on each side. you might get a little bit better if you run a little hotter cam then a 255. Ive seen motors here in jax fl with 90+ hp and around the same torque i got with hotter cams the curve just comes on much later then mine. NOW with all that being said if you live near me please contact me and we can go into depth about any motor work you want done to your motor. For instance I have a Dyna sitting in my garage as we speak with 107 hp and 115 torque out of a 103 cubic inchs. however he has about 2500 in his motor. Hope this helps
Darryl
Old Oct 21, 2008 | 06:35 PM
hogwash's Avatar
hogwash
FYI HD has a 103" Stage IV available in their 09 SE catalog.
http://www.harley-davidson.com/en_US...ng/US_SE_P.pdf
Old Oct 21, 2008 | 08:10 PM
brihvac's Avatar
brihvac
Im going to do a 110" this winter. Im going to get a local motorcycle machine shop to do the engine itself. Im gonna get the heads and everything done. The dealer suggested I get it done at the machine shop to save money.
nutter
May 3, 2012 04:30 PM
Jester750
Sep 20, 2011 01:47 PM
musicnbikes
Jan 8, 2011 09:43 PM
Vettepro
Mar 23, 2008 10:32 AM
jmbear328
Apr 18, 2007 10:18 PM
