Engine Noise
Old Oct 21, 2008 | 09:28 PM
zyepod's Avatar
zyepod
Default Engine Noise
Hope I'm not beating this subject to death. I have an 08 EG with engine noise. I read in another thread someone stating they couldn't believe how much noise his EG made. Are the engines naturally noisy? I have what sounds to me just like a lifter tap. I notice it mostly around 55 to 58 mph. Above 60 it stops. I'm using Mobil 1 20/50 which at next oil change I'm going back to 10/40. Is this noise normal or should I see the dealer?
Old Oct 21, 2008 | 09:41 PM
Javawave's Avatar
Javawave
air cooled V twins make alot of noise. No way to tell without hearing your bike, but it is probably just normal. If you are coming off a water cooled bike, you will have alot of sounds to get used too. but they are pretty much normal.
Old Oct 21, 2008 | 09:48 PM
max1's Avatar
max1
I was told at a few dealers that the 96 engine makes more noise than the 88s. I agree with you on the lifer tap, mine too. A ten yr old 88 I have is quiet. Suppose to be the changes in the 96 engine. I really dont know, I wish someone did, I would fix it.
Old Oct 22, 2008 | 07:50 AM
Dennydp's Avatar
Dennydp
Fairing/lowers trap a lot of noise.96s seem to make more then 88s.
Old Oct 22, 2008 | 08:18 AM
cadman311's Avatar
cadman311
It sound like it don't like cheap oil replacements. It wants HD synthetic oil.
SportsterRider85
Aug 26, 2017 03:14 PM
missboy
May 15, 2011 10:25 AM
Blueharley
Oct 1, 2010 06:54 AM
1peter
Jun 5, 2009 11:10 PM
Custom07RKC
Mar 12, 2007 11:20 AM
