Think about it this way:
They put in a map in for you. They are adjustable 3 pots inside the little door. You can richen the mixture but you can not lean it. If it is set at 0-0-0 it's the same as not having it.
Even Honda riders don't use it any more.
jim
COBRA has been the Metric King of aftermarket for years... And just started doing stuff for HD's
If your looking for EASY SET-UP and INSTALL - Look at V&H FuelPak (but they have limits also.. If the Stage 1 is as far as you want to go then the FuelPak works GREAT!
If you plan on a Stage II - Look at the Power Commander or SERT...
yep, have one on one our (2008 883c), works great have had it on dyno and tinkered with it. the factoring settings are fairly close. I have an flhtcu also and I wish i would have put one on it instead of the harley download.
I had one on my 07 Ultra for about three months, it was a waste of time and effort.
I have the Stage 1 kit and true duals installed also.
The gas mileage went from 45 to 31 mpg.
I eventually switched to the Vance & Hines Fuel Pak with the same mods and mileage is back to the low forties with a lot more throttle response than stock or with the Fi2000r.
